MPPT controller timer settings (1 Viewer)
Xan
158
102
Bristol
I'm new
New solar kit now freshly installed.
MPPT controller is one of these
Currently have left everything on factory settings, should I change anything?
Mar 12, 2012
1,395
1,612
Bridgend, South Wales
Just started!
As far as I'm aware, you set the timers both to n = not used or something like that.
I believe they refer to the terminals labelled 9. These are not used in my installation and I believe they can be used for attaching timed lights or similar.
John
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
It depends if you have a load connected or not. The battery discharge level set to 10.5V I think is too low for comfort 11.9 is a discharged battery 10.5v and if you do not charge fairly soon you could kill the battery. The load is on a timer unless you select manual and have it on permanently. If no load is connected then you lose the over discharge protection.
43,329
49,444
wot roger sed !
set battery type to your particular battery type..gel, lead acic etc then leave alone.
the timer mode is for night lighting etc and will turn on and off a porch light etc if connected.
it does nothing when the panel is providing charge current...only works at night or if the panel is covered etc...and will only provide maybe a couple of amps max.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The battery cut off voltage will be UNDER LOAD and does not reflect the state of charge.
