Lot lover
Some have them, some don't. We prefer to use the 30 kph lanes though I am not brave enough to try them at that speed.
I am just touching 3m if u measure to height if folded sat dish...
Are there 3m height barriers? As would not want to test it lol
Lucky you Jon, they just come out the booth and laugh at us "giant" he said.Ive spoken to a couple of french guys with tag axles who say - it is a contentious issue - but they only ever pay class 2. On the odd occasion its clicked to class 3 with us I push the button and get it reduced. They re not usually inclined to put up a fight.
I know people who are over 3500kgs but under 3m who regularly use sanef tags.
If you take out a SANEF/liber-t tag now you sign a declaration that you will only use it in a class 2 vehicle so what you say is not strictly true.In practice you will not be detected as class 3 if you are under 3 metres high regardless of weight.
We are well over 3500kg but have only ever been charged as class 2 both without a tag and with one.
The other thing to remember is that the tag is registered to you personally to be used in whatever vehicle you happen to be travelling in. Sanef do not hold specific vehicle details. They even provide extra mounting brackets to make it easy to switch your tag between vehicles. The tag is a payment method, nothing more, it doesn't guarantee, or even make it more likely, that you will be detected as a particular class.
Martin
I didn't sign anything to get my tag applied online when booking tunnel got tag free.If you take out a SANEF/liber-t tag now you sign a declaration that you will only use it in a class 2 vehicle so what you say is not strictly true.
Martin
Not what it says here, https://www.saneftolling.co.uk/subscriptionNo actually you don't do anything of the sort.
The tag is not tied to any specific vehicle or class. It is registered to me personally and can be used in any vehicle I'm travelling in.
I can use the same tag that I use in my motorhome (detected as class 2) in my car as class 1, with a motorcycle if I had one as class 5, in anyone else's car, motorcycle or motorhome or any other vehicle I choose as long as the system detects it as class 1, 2 or 5.
If I happened to be travelling in your motorhome and tried to use it then it wouldn't work because the system would already have detected you as class 3. In exactly the same way an HGV tag would not work in my motorhome because the system detects me as class 2 which such a tag can't be used for.
The system has already detected your vehicle and decided what class it is going to charge you as before it even starts to look for a tag of any description.
The tag is nothing more than a payment method. It has absolutely no bearing on what class you are detected as.
The only restriction other than that is that you are not allowed to use it in two separate vehicles at the same time i.e. if you are travelling in convoy you can't go through a barrier and then stop and pass it back to your mate behind you. I've no idea why they've felt the need to specifically ban that. Someone must have tried it I suppose.
many thanks for that. I have now received mine and today instructed my handyman to fit mine. it does seem to be fitted discretely behind the mirror on the shaded area. think I will only know the outcome once I get to the barrier.As a solo traveller this will solve a lot of stress for me if it works.Edit- you mount it in the shaded area behind your rear view mirror.
You may have to put it lower if you have a big overcab overhang I think some members on here just lay it on the dash and it works.where do you mount the tag on the windscreen? Does it have to be low down due to the overcab on a coachbuilt?
You can mount in the shaded area near the mirror but I found it did not always work but a rather agitated French toll both lady lent into the cab and grabbed the tag and threw it onto the bottom of the dash , it worked every time after thatwhere do you mount the tag on the windscreen? Does it have to be low down due to the overcab on a coachbuilt?
Think you can still use even over 3m but I suppose you would be charged class threeOur current MH is 3.05m high so I've never chanced buying a tag.
However, I'm insisting on our next MH being 3m maximum, including any gubbins on the roof. Those tags are just too useful to ignore.
