Motorway Toll Tags – and I get a rollicking! (1 Viewer)
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
Some have them, some don't. We prefer to use the 30 kph lanes though I am not brave enough to try them at that speed.
D
Deleted member 29692
I am just touching 3m if u measure to height if folded sat dish...
Are there 3m height barriers? As would not want to test it lol
No, the lanes with height barriers are 2m for cars only. The other lanes detect height with cameras or something.
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
The only height barriers are in the "car only" lanes and are set at about 2.2m.
The 3m height is measured by some electronic sensing device. If you are slightly over 3m, the system will charge you for Class 3 (as opposed to Class 2). You then need to press the help button and issue the words "camping car" and they should then reduce the charge to Class 2. This procedure is for the normal lanes.
Jun 10, 2010
8,507
20,219
Shrewsbury (sometimes)
N&B Clou Liner MAN
Ive spoken to a couple of french guys with tag axles who say - it is a contentious issue - but they only ever pay class 2. On the odd occasion its clicked to class 3 with us I push the button and get it reduced. They re not usually inclined to put up a fight.
I know people who are over 3500kgs but under 3m who regularly use sanef tags.
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
Lucky you Jon, they just come out the booth and laugh at us "giant" he said.
Martin
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
In practice you will not be detected as class 3 if you are under 3 metres high regardless of weight.
We are well over 3500kg but have only ever been charged as class 2 both without a tag and with one.
The other thing to remember is that the tag is registered to you personally to be used in whatever vehicle you happen to be travelling in. Sanef do not hold specific vehicle details. They even provide extra mounting brackets to make it easy to switch your tag between vehicles. The tag is a payment method, nothing more, it doesn't guarantee, or even make it more likely, that you will be detected as a particular class.
If you take out a SANEF/liber-t tag now you sign a declaration that you will only use it in a class 2 vehicle so what you say is not strictly true.
Martin
D
Martin
No actually you don't do anything of the sort.
The tag is not tied to any specific vehicle or class. It is registered to me personally and can be used in any vehicle I'm travelling in.
I can use the same tag that I use in my motorhome (detected as class 2) in my car as class 1, with a motorcycle if I had one as class 5, in anyone else's car, motorcycle or motorhome or any other vehicle I choose as long as the system detects it as class 1, 2 or 5.
If I happened to be travelling in your motorhome and tried to use it then it wouldn't work because the system would already have detected you as class 3. In exactly the same way an HGV tag would not work in my motorhome because the system detects me as class 2 which such a tag can't be used for.
The system has already detected your vehicle and decided what class it is going to charge you as before it even starts to look for a tag of any description.
The tag is nothing more than a payment method. It has absolutely no bearing on what class you are detected as.
The only restriction other than that is that you are not allowed to use it in two separate vehicles at the same time i.e. if you are travelling in convoy you can't go through a barrier and then stop and pass it back to your mate behind you. I've no idea why they've felt the need to specifically ban that. Someone must have tried it I suppose.
Jul 29, 2013
9,071
18,515
Salisbury
Hymer B678DL A class
since 2011
Martin
I didn't sign anything to get my tag applied online when booking tunnel got tag free.
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
Not what it says here, https://www.saneftolling.co.uk/subscription
Martin
camperlove
236
180
kent
fiat ducato mwb
17 years
After I brought mine , I got an emAil saying I get 5 £ off and who ever referred me get it off . Does anyone want to refer me? Thanks.
RetiredPope
149
1,013
Taunton
Chausson Flash 640
4yrs so still a newbie
where do you mount the tag on the windscreen? Does it have to be low down due to the overcab on a coachbuilt?
Sep 12, 2014
182
176
Merseyside
Transit coachbuilt
8years & counting
I've just returned from 12 days in France with a sanef tag, it was brilliant, no messing with coins or even worse credit cards !
Well worth the money !
Edit- you mount it in the shaded area behind your rear view mirror.
camperlove
236
180
kent
fiat ducato mwb
17 years
many thanks for that. I have now received mine and today instructed my handyman to fit mine. it does seem to be fitted discretely behind the mirror on the shaded area. think I will only know the outcome once I get to the barrier.As a solo traveller this will solve a lot of stress for me if it works.
Claire Cymru
Caernarfon
Autosleeper Eton
Newbie
We have used our Sanef tolling tag on 4 different vehicles in the last 2 years. We got it with a deal via Eurotunnel. I generally travel alone so it's a must.
Jul 29, 2013
9,071
18,515
Salisbury
since 2011
You may have to put it lower if you have a big overcab overhang I think some members on here just lay it on the dash and it works.
Howard H
4,832
4,795
West Lancashire
Benimar mileo 294
You can mount in the shaded area near the mirror but I found it did not always work but a rather agitated French toll both lady lent into the cab and grabbed the tag and threw it onto the bottom of the dash , it worked every time after that :LOL:
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Our current MH is 3.05m high so I've never chanced buying a tag.
However, I'm insisting on our next MH being 3m maximum, including any gubbins on the roof. Those tags are just too useful to ignore.
Jul 29, 2013
9,071
18,515
Salisbury
since 2011
Think you can still use even over 3m but I suppose you would be charged class three
magicsurfbus
4,673
10,127
NW England
Since 1997
Fair point, but we're always charged Class 2 at the booths and automated barriers so I didn't want to chance it with an infra red beam or whatever on the Telepeage lane. We want rid of the Luton anyway, so hopefully the next one will be the right height.
