Motorhome won't start (1 Viewer)
Gringo
36
1998autotrail Cheyen
12months
My fiat Ducati won't start it has been ok all summer but now it turns over but won't start it's a 1998 2.5 d
G
Gringo
36
12months
Yes I thought that myself but is there a relay or do you just need to change the plugs
Daniel. M
92
999
Bromsgrove
Rapido 9090DF
Getting there šŸ¤«
I changed my plugs on a transit, and it sorted the problem, but worth checking the voltage to them first.
Top tip is soak them in WD40 for about an hour prior to taking the old ones out
JockandRita
11,498
150,439
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Have you tried turning the ignition on 2-3 times, and allowing the glow plug light to extinguish, then turn her over?
I had 1999 2.8TDI engine in our Hymer, and in winter, 2-3 warm ups of the glow plugs first before cranking her over, did the trick every time. (y)
Good luck.
Jock. :)
Dec 12, 2010
5,444
21,785
Cumbria
Has it got an immobiliser fitted, is there any sign/smell of a diesel leak in the engine bay ? How confident are you with spanners ?
G
Gringo
36
12months
I am pretty good with petrol engines but a novice with all things diesel the glow plugs are pretty difficult to get at and I don't want to pull thiatwithout remoat
43,398
49,990
Before pulling the plugs check they're getting power.
If you can reach the plug end stick a meter on then turn on the ignition.
Don't know what voltage they run at but any voltage will prove there's power getting there as a starting point to trouble shooting.
Nov 4, 2011
5,973
39,777
Uk
Have checked fuel getting through. I had a problem with mine a few years ago, turned out to be a fault fuel filter.
Jul 24, 2015
374
947
Ramsgate Kent
Fiat ducato c class
5 years
Could be a few differentthings.... diesel leak off pipes leaking .. diesel pump gasket gone..both letting air into the system.
Imobilizer from the pump...most people take them out before they bust and leave you stranded.
Try some easy start first.
