motorhome tyres (1 Viewer)
0ntheroad
4
stourbridge
aclass
hi all got a tag axle autotrail fiat
not very good on grass as i get stuck
can you put m&s type tyres or winter tyres on
are they better help
the tyre size is 225/75/16
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
i would guess you can as long as they are the correct load rating. but, might be a bit noisey and a slightly rougher ride?
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
could be cheaper to carry a pair or 2 of these and park on them
Link Removed
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
We run M+S winter tyres on our tag axle all the time as we use the van all year round and never worry about parking on grass. We regularly park on snow and only need chains in extreme conditions and we are fully loaded with a 650 m/bike in the garage. We are only 25ft with a short overhang though which can make a big difference in front wheel grip. Has no effect on the ride that I can tell the van runs really smooth at 60/65mph all day long
0ntheroad
4
stourbridge
aclass
It's getting to the pitch that's the problem or to the water tap on cl type sites
Why don't fiat put a diff lock on motorhomes
0ntheroad
4
stourbridge
aclass
Do you fit them to just the front or all round
What make are they
Jul 28, 2010
1,710
617
The world
Small car
Why don't fiat put a different lock on motorhomes
Because they are crap at making Moro homes
( runs for cover )
They just use a van base and add thd motor home fittings and body
They use a base that has just enough power to pull its own ass along
Then we fill them with water tons of stuff then. Moan how bad they are to drive
0ntheroad
4
stourbridge
aclass
i have Michelin Camping tyres on it i was after some block type tread 4x4 type tyres 225/75/16 118r fitted
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Had the same as you and used to get stuck EVERYWHERE !!!! ( lots of folk on here will witness this LOL !! )
Before we went to Spain for winter I had a set of Hankook 10ply van tyres fitted..
First thing we noticed was the noise level dropped by at least 50%.. We could speak in normal voices and hear each other easily ( actually, never realised how much cab noise we had until it went ! )
Next thing we noticed was we stopped getting stuck everywhere we went ( 4.1t on a pug boxer chassis ).
I think this was REALLY brought home to us when we was one of the few vans that managed to drive out of the quagmire that was the field at Newark show ground late Saturday evening.
I got most of the way out of the field but when I hit the 6"+ deep mud I sort of ground to a halt..
As I got stuck everywhere usually I just turned off and called for a tractor........... only to find out the tractor driver had already gone home
The choice was sit in the field partially blocking the gate until morning, or give it a go.
Started up, popped it in to 2nd and let the clutch out.. Yes, the wheels span a little but by the cringe, we managed to crawl our way out !!
Tyres have now been on for about 6k miles and I could not be more pleased with them ( Oh and yes, same size as yours too :thumb: )
