Motorhome Security Success (1 Viewer)
Mar 29, 2014
16
32
Norfolk
Autotrail
First post on here so - hello everyone!
Drove from Calais to Dijon on Sunday night & ended up desperate for rest on an aire. Woken at 4am by lights coming on in our van. Got up & found drivers door had been unlocked & someone had tried to open it. Lights coming on (or me standing up in my boxers) must have scared them off. Fortunately we had used the good advice given to us when we first had a motorhome & threaded the seat belts through the door handles, over the seats & into their holders. This meant the door couldn't be opened more than an inch & belts would have had to be cut to open the doors. Just thought it was worth mentioning so that any newbies like I was just a few years ago know there is a free & effective way of securing your doors & to be wary of parking up overnight on some motorway Aires.
Jan 3, 2008
3,344
5,363
Pakefield, Lowestoft, Suffolk, UK
Looking
M
Motorway Aires are a non starter for me either in Europe or UK. Glad they isn't get in and your ok though.
SMB
Apr 26, 2013
1,231
1,348
Spain
Coachbuild
Fulltiming since February 2013
A cargo strap across the door handles is also effective though I have now had Milenco door stays fitted, along with a Milenco external bar across the hab door which locks from the inside as well. I have Lock m out fittings on the windows along with Milenco window alarm (no I don't have any affiliation with Milenco!), every little helps. Steering lock always on when I leave the van. But, as mentioned, I also avoid motorway aires.
tonka
10,848
21,562
Cannock, Staffs
A class Burstner 800
Since 2000
Glad your ok but as been mentioned on here before, some are aware of using the seat belts and can cut them..
So this gives you an added complication of not being able to use the belts, or being stopped for not wearing them. As well as the expense of replacing the belts..
Might be worth investing in a steel wire or chain when you can...
Stay safe..
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Door deadlocks for me -get them from your hardware shop not expensive and fit them yourself .Puts scummy off as soon as it sees them .
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I fitted some Yale deadlocks after finding the offered Abus ones were far too expensive, I welded up a fitment that stepped the lock ou to the correct distance and fitted one to each door of the Hymer, The left door is a special the would have been the drivers door and had a place for the lock but just too close to the outer skin to get the lock into it hence the tigwelded alloy tube spacer. The hab door was anther one that needed a wooden block made to space out the lock to catch the edge of the body. These are really good security locks and only cost £14 each for the basic lock with the yale key set. I am going to fit a pair to the rear garage doors for when we are parked up so that we do not depend on the plastic catch variety fitted.
Aug 7, 2007
669
608
Dundee
Elddis Autoquest 195
since 1975
Cheap but very effective option is to do as i did.Went local ship chandlers and had a 6mm dia plastic coated wire strop made up to the correct length c/w a loop/eye at each end .
Thread them through the armrests and padlock them together, job done, doors cannot be opened all for the sum of £15.00
Bonus is that the moho can still be driven away with it on if required !! We have had on in use for past 10 years.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Your allowed to remove it when your driving:rofl::doh:
Feb 17, 2009
359
1,377
Cheltenham
AS Broadway FB
Since 2006
Any idea how they opened the doors, any damage?
M
Mar 29, 2014
16
32
Norfolk
Autotrail
Not certain how but suspect either a skeleton key or some way of triggering the remote - no damage evident & everything working fine
Thanks for all the helpful comments made on here - must say I recommend the lock m out fittings - they seem a simple but effective solution to the vulnerability of the Windows. Have just bought a cable alarm to stretch across from door handle through steering wheel to door handle and back - fits tight & if cut it triggers a very loud alarm
Weather & tranquility in Provence this last few days is making it all worth it
irnbru
13,518
31,151
Glasgow
Benimar 264
11 yrs
Can you give me a link to where you bought it please.
R
Robert Clark
Good job you were awake
A good deterrant may be less stressful in future
Safe travels !
DBK
18,046
48,208
Plympton, Devon
PVC, Murvi Morocco
Not certain how but suspect either a skeleton key or some way of triggering the remote - no damage evident & everything working fine.
Have a look around the bottom of the door locks, that is along the bottom edge of the big black plastic thing which has the door handle. They may have pushed something sharp in, either through the plastic itself or perhaps under it. Assuming it's a Fiat this is a known way of getting in. You can get metal plates which fit underneath the handle to defeat this type of attack.
Nov 25, 2013
1,125
1,778
kent
Swift Kontiki 669
Since April 2013
I ratchet strap the doors together, and of course avoid most toll motorways, too expensive for class 4, always pick a small village aire or somewhere from France Passion, for the cost of a bottle du vin.
Nov 6, 2013
3,201
230,763
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
I assume you turn the internal alarm off when you go to bed, or do you wear earplugs? :)
We always set our Strike Back at night but as you say DBK we disarm the internal sensors. (y)
DuxDeluxe
14,668
73,005
Planet Zog
A woosh bang van
since 2008
No wonder Mrs Deluxe complained about the noise....
.....I assumed it was just my snoring:blush:
DuxDeluxe
14,668
73,005
Planet Zog
A woosh bang van
since 2008
Including you I would not to be inside if it goes off.
Good alarm system - one of our dogs had parked himself inside the van once and went to sleep without us realising he was in there. Woke up and all hell broke loose - one rather shocked looking dog.......
Feb 22, 2008
12,268
45,075
Norfolk
Nearly Tugging
Since 2004
I always keep my Fenix Cree torch under my pillow , enough to near blind any intruder, as well as alarm set.
fred flintstone
139
75
lincoln
Pilote P690
Since 2007 on and off
Me too, cheap and easy
M
Mar 29, 2014
16
32
Norfolk
Autotrail
Just checked this morning - definitely what has happened - something like a knife has pushed into the plastic as I can see the hole & plastic burrs from the entry point. Thanks for the info on that
D
DL42846
I used to have a bar lock before in my old camper but it was always in the way when not being used. I now also use a ratchet strap at night. It also has other uses, one of which is to hold the main door open in strong winds. And it holds my scooter in place in the boot.
Feb 27, 2011
14,783
76,428
UK
Self Build
I did look into using a strap but it wasn't practical for my van as I have a separate living/cab area separated by a bulkhead.
I ended up fitting my own deadlocks which I bought from http://www.van-locked.co.uk
For me physical prevention and making it as inconvenient and as risky as possible comes before alarms. Followed by Alarms, followed by clever gadgets.
Here is how I fitted them on my van.
https://www.fulltiming.info/self-build-motorhome/fitting-deadlocks
On the Alarm front I have one of these to fit. (£20 ish) But don't let the low price put you off.
http://amzn.to/2ccSeQd
It has;
remote immobiliser,
GPS Tracker
Remote mike so you can listen in.
Alarm
Geo Fencing
DBK
18,046
48,208
Plympton, Devon
PVC, Murvi Morocco
These are the plates - not cheap but apparently not too difficult to fit.
Deneb
1,598
2,334
Europe
PVC
Just fitted a set to my van, but I got them from Trade Vehicle Locks. They're a modified version with an extension to the stainless steel plate under the lower edge of the plastic handle and the lock mechanism is also boxed in inside of the doorskin.
Broken Link Removed
DBK
18,046
48,208
Plympton, Devon
PVC, Murvi Morocco
Broken Link Removed
Thanks. How much were they? The website won't tell me unless I register for an account! Very odd.
