Motorhome electric s
Discussion in 'Introduce Yourself' started by stephen nicholas, Feb 11, 2015.
  1. stephen nicholas
    stephen nicholas Read Only Funster
    Feb 11, 2015
    south wales
    Hi guys ive own my fiat ducato lunar A630 since july 2014
    the last week ive had a little problem with the electrics on 12v I switch the power on and after a short while the power trips but does not trip the main fuses
    1. I have had the 2 leisure battery drop tested and their fine full of power??????
  2. Puddleduck
    Puddleduck Funster Life Member
    Jan 15, 2014
    6,776
    14,623
    Scottish Borders
    Can't help with your query but suggest you post on a different forum category such as tech/mechanical and you will get more answers - some might be useful :)
    Also if you pay your subs (only £10 a year) you will get full access to the whole site. It's the best £10 you will ever spend and it gives you loads of discounts.
    • Like it Like it x 2
  3. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Ditto.
    What puddleduck said.
    Definitely best tenner on anything motorhoming.
  4. C200JK
    Dec 27, 2014
    963
    3,174
    Ireland / London
    What does it trip?, the CB's?
    If so, and your batteries are OK then you have a load greater than the CB rating ...or a faulty CB.
    Either way then find what circuit is tripping it out, using amp meter in series on the affected circuit. That will establish what and the extent of the load.
    I take it that it isn't the 240 volt trip that is dropping out, if it is then an inverter may be in somewhere.
    Sorry but can't help without more info as your post is a bit vague.
    • Like it Like it x 1
