mot
Discussion in 'American RV's' started by roycondor, Aug 8, 2008.
  1. roycondor
    roycondor Read Only Funster
    Oct 26, 2007
    52
    South Wales
    hi all,
    taking coach for mot on Monday, first time for me, is there anything in particular i should check before taking it, bulbs e.t.c are o.k, how is the parking brake checked as it cant be checked on rollers, workhorse chassis, transmission brake I think, I dont know which is worse, a visit to the dentist or an mot tester, they are both torture:cry-smile:
  2. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Roy
    You'll be fine don't worry ..... make sure you tell the tester it's a trans hand brake
    never had a transmission brake myself
    Have your rear seat belts ready to be tested
    It's easier than a trip to the dentist :thumb:
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,689
    5,843
    Mansfield,Notts
    Yes thats easy to see Tony cos its a trans FOOT brake:Rofl1::Rofl1::Rofl1:
    and they are tested :Eeek::Eeek::Eeek:
    Geo
    PS dont worry Ruth will teach you to drive the big un
  4. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Full timing in the van
    i will keep my fingers crossed for u :thumb::thumb:
  5. roycondor
    Oct 26, 2007
    52
    South Wales
    parking brake
    Hi Geo
    its not a parking foot brake, works when you pull a knob on dash:Wink:
  6. Tony Santara
    Jul 26, 2007
    1,494
    114
    Yes but how are they tested Grasshopper :Wink:
  7. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    My RV was tested by VOSA centre on a rolling road the same as the other brakes. Protesting that it might damage things or, that it was a parking not an emergency brake got short shrift - the reply was either on the rolling road or driving down the road take your choice it's going to get tested. :Eeek:
    They're going to test the brake whatever the type.
    Check all your lights as well as the headlight beams against a wall or something and know how to adjust the beam - even VOSA will let you have a couple of minutes with a spanner if they're off.
    Does your rear fog light illuminate the switch or an indicator on the dash when on?
    Check all seat belts - wipers/washers work properly, horn, has it a secure fuel cap
    :Smile:
    Keith
    Keith
  8. Geo
    Jul 29, 2007
    9,689
    5,843
    Mansfield,Notts
    Tony Keith has answered admirably:thumb:
    but I'm sure he said reversing lights when i first read it, i will give him the benefit of any doubt as a good MoT tester should:Rofl1:
    Geo
  9. superk
    Aug 22, 2007
    503
    57
    Devon
    Must be those bedtime brandies Geo :Rofl1:
    or editing slight of hand :Wink:
    :Smile:
    Keith
  10. Geo
    Jul 29, 2007
    9,689
    5,843
    Mansfield,Notts
    Its OK i thought i was seeing things, but it turns out it was only a mirage:RollEyes:
    Geo
  11. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: I have taken several different RV's for MOT's. Two had Lever hand pull Transmission brakes. The others had foot applied Transmission brakes.
    When testing the Lever hand pull Transmission brakes. I held the brake on and was ready to release.
    Similar with the Foot applied Transmission brakes. I pushed the brake on with my foot while holding the hand release knob ready to release if necessary.
    Never failed on a Transmission brake yet. :Wink:
    BTW. The first time we ever took an RV (our old Coachmen). When I applied the hand lever brake. The RV reacted like a Bucking Bronco. Not very pleasant. I soon learned what to do after that. :Eeek:
  12. roycondor
    Oct 26, 2007
    52
    South Wales
    Thanks guys and lasses for your replies,
    If the rv has a parking brake and not an emergency brake, how do you stop it if footbrake system fails, :pray:and, how strong is the transmission, will it survive if parking brake is operated either on a rolling road or open road
  13. Thepips
    Thepips Trade Member
    Sep 26, 2007
    500
    Basingstoke
    Mine's a proper brake operating on the transmission instead of the rear brakes. Mine's air operated so it's either on or off. It's not the same as the park position on the automatic gearbox.
    When I took mine in for the test I followed instructions called out by the examiner. Certainly didn't seem as brutal as a few years ago. I put the brakes including the parking brake on when instructed and the road then monitored the amount of force needed to turn the wheels.
    Regards
    Doug
  14. Jan Pendreigh
    Jan Pendreigh Read Only Funster
    Feb 23, 2008
    195
    Our rv MOT was at VOSA in Peterborough. After the rolling road test in the big shed we were requested to drive round outside and reverse up a ramp in order to test to parking brake. The ramp was so steep that we were unable to reverse up it because of the towbar and overhang. Fortunately the examiner passed us anyway. Phew!!
    Good Luck
    Jan
  15. roycondor
    Oct 26, 2007
    52
    South Wales
    :Eeek::Eeek:
    checked coach on Sunday afternoon and found rear fog lights not working, traced cable and found that it had been rubbing on rear wheel and shorted out, must have blown a fuse somewhere but cant find it, so ran a cable from front fog lights in order to get rears to work, took it for mot, tester found a nut and bolt loose on steering somewhere and tightened it and then :thumb::thumb::thumb:.turned out to be not quite as painful as dentist after all
  16. superk
    Aug 22, 2007
    503
    57
    Devon
    :clap: Congratulations (I'm assuming it passed - you didn't say:RollEyes:)
    :Smile:
    Keith
  17. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Nice one:thumb:
  18. roycondor
    Oct 26, 2007
    52
    South Wales
    Hi kieth,
    yes passed, :Smile::Smile:
  19. Tony Santara
    Jul 26, 2007
    1,494
    114
    Nice one Roy
    Told you it wasn't so bad :thumb:
  20. Geo
    Jul 29, 2007
    9,689
    5,843
    Mansfield,Notts
    Drat:Doh: another happy customer:Rofl1::Rofl1::Rofl1:
