MOT problem (1 Viewer)
skinnyhead
4
waterlooville
aclass
Boris has just failed his MOT on left hand idler arm joint lift among other odds and s..ds.Can anyone confirm that a small amount of play is permissible on this joint?It is a 2005 workhose chassis.:Sad:
darklord
1,241
1,230
essex
coachbuilt
three years
The amount of play, unfortunatly, is more or less decided by the tester, if you dissagree, you obviously have the right to appeal, or you could just take it to another garage, maybe for a "pre MOT" to see if they would fail the joint, but, IMHO, if someone has pointed out that you have a safety critical part on your vehicle that is in a suspect state, I would err on the side of caution, and change it...probably the quickest and cheapest option anyway:thumb:
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
I agree with you on that
If I ever have a part that is slightly iffy then it is changed... never had an advisory.. I have a pre MOT and make sure it is going to pass. Down in Kent I use a main Renault Truck garage, they put the RV through a buy in test and that is 8 pages of checked items.. then it goes to a Mercedes main truck repair and service workshop in Eastbourne for the MOT proper. I know the vehicle is safe then to drive.. not worth the risk... just get the new part and fit it and re MOT.
Bob
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Your tester should be working within the testers manual very little opinion is reqd
without hands on, no one can give you a valid answer
Relative movement due to excessive wear MUST be distinguished from relative movement due to built-in clearance or spring loading of a joint.
Play in ball joints or pivot points must not be regarded as excessive unless it is clear that replacement, repair or adjustment of the component is necessary.
Geo
43,330
49,446
Sorry cant really help with your question but....
the testers decision is final, unless you appeal and get lucky, and it is now on the MOT database as a fail.
as an aside, my Ford F53 chassis passed last year with a little lateral play in the N/S kingpin...the tester said it was no where near a fail condition but it was listed as an advisory so is now on record.
motor roamin
May 23, 2010
1,541
792
Leicester
2 mins
Chevy Idler arms have play in them from the factory.....however aftermarket replacements don't......I found this out when I complained to a chevy dealer in the states that my six month old truck that I had from had excessive play in the steering idler :Blush: I was very red faced when he put a new truck on the lift and it had the same play in the idler.
That truck was a 96.
In answer to your question you may well be best just changing it for an aftermarket one.
All the best Rick
