MoT News Nevara and the like
Discussion in 'Fifth Wheelers' started by Geo, Jul 28, 2009.
  1. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    At the moment vehicles such as the Nevara, that have a DGW in excess of 3000 KG up to and including 3500KG (technically a goods vehicle) benefit because of its classification as a "Duel Purpose Vehicle" can be tested under class 4 MoT (Car)
    This is about to change!!!
    Motor Vehicle Test Regulations will in 2010 re classify these vehicles into the Class 7 Goods Vehicle test scheme
    it is also worthy of note, as you know, Goods vehicle have lower speed limits on single and duel carriageways, these lower limits also apply to Duel Purpose Vehicles
    Geo
  2. zaskar
    zaskar Funster
    Sep 25, 2007
    988
    98
    UK
    Great!:Doh:
    Could you tell me what this will mean from an owners point of view, with regard to cost, any extra things looked for in the test and test facilities available to the public?
    Ta
    edit= think I've found one bit of the above. The fee goes up from £54 to £57 according to the VOSA.GOV site.
  3. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    If it goes to Class 7 MOT, you might have to have and use a Tachograph!
    I don't want to spread alarm and despondency amongst the ranks - but it has been talked about for the last year or so on the dealer circuit.
    In essence, it means that your vehicle becomes an 'articulated' vehicle rather than a caravan. I am not really into the details but apparently it is all to do with the amount of weight being transferred onto the tow vehicle when the trailer is attached.
  4. robrobc
    robrobc Read Only Funster
    Oct 16, 2008
    243
    Cotswolds
    As I understand it, this relates back to the 20% ruling, in so far as any drawn vehicle that bears more than 20% of its weight on the Tow vehicle will (if the new regulations come in to force) have to have a tachograph fitted.
    There is still as far as I am aware great uncertainty as to whether this is to be only for "commercial" vehicles or if it will include leisure vehicles.
    The other challenge faced which is, as yet, not clarified is, at what point a trailer clearly designed for leisure pursuits becomes a commercial vehicle and thus needs to be recategorised. Does this mean a new category over and above caravans? who knows:Doh::Doh:.................I guess what will be certain is that it will add to the current confusion. :Eeek: No change there then.
  5. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    That is the general outcome of the discussions that I have heard about - "if and when" the 5'er is designated as NOT being a caravan.
  6. Geo
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    You could have fooled me:RollEyes:
    Total Hogwash!!!!
    Next to no differance to the vehicle owner.
  7. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    See <here> for the current explanation of whether you need a tacho.
  8. robrobc
    Oct 16, 2008
    243
    Cotswolds
    Unless I am missing the point here, your flow chart is for current and clearly leads you to a "No Tacho needed" conclusion.
    This is not what is being discussed at present in so far as future legislation. The key for the future will be the criteria of definition between private and commercial.
    Let's wait and see, but as has been discussed to the point of exhaustion elsewhere, it seems impossible to reclassify an unknown quantity of vehicles already in operation. i.e. retrospective will be a non starter.
    Rob
  9. Geo
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    The question is clearly answered in box 1
    Is the vehicle used for hire or reward or used for commercial carraiage of goods
    Answer NO
    is a Tachco reqd answer NO
    you will be telling me their banning A frames next:Doh:
  10. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Aaaagh, Yes - A frames - now that you have raised the subject........:Doh::Doh::Doh:
  11. robrobc
    Oct 16, 2008
    243
    Cotswolds
    It was all going so well until the mention of A frames :BigGrin::BigGrin::BigGrin::BigGrin:
  12. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    hi, the construction n use definition of an artic is that atleast 20%of the loaded trailer must be super imposed on the tow unit. most 5ers are not artics .they are living vans . if over 3,500kg must be mot,ed .if under exempt. if you look at v112 form from dvla a navara could be mot exempt if it pulls a proper artic trailer. as for private use i do have a tacho,dont use it with discs as i am exempt as private . it gets silly but after speaking with the local traffic examiner he says even if the camper truck is what he would class as a camper used private weghing 7.5 ton was pulling a small trailer and it was again seen to be full of items conected to camping he would let it go with no tacho working. anyone confused can speak to there local traffic examiner they are very helpfull. i say get a truck over 3,500kg get an artic 5er use v112g much better.
  13. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    as for using the ntta . they dont control anything.if you look at vosa book ref 277535 drivers hours and tachographs (revised 2007) page 10 in the exemptions vehicles or combinations of vehicles with a maximum permissible mass not exceeding7.5 tonnes used for the non -commercial carriage of goods ..... quite possitivly says exempt .If over 7.5tonnes used for non commercial should use tacho.
