mobility scooter (1 Viewer)
scotjimland
2,327
10,094
A Woosh bang
can anyone tell me the best way to charge a mobility scooter on our RV ,ta :Cool:
* On EHU and plug into one of the RVs 230v sockets .. (via an extension cable if required.)
* Off EHU you could use an inverter, but this would quickly drain the RV leisure batteries, the last thing you want to do when off of EHU ..
* Or use a 230v Inverter type generator such as Kipor or Honda , size required depends on the load of the scooter charger
Les
Apr 18, 2008
301
4,162
Seaford
Low Profile
Mobility scooter charge
I use a Inverter works OK also charge on move leaving inverter on to keep batteries charged, inverter needs to be big enough for charger load
also charge when ever you can keep it topped up
good luck
Les
ArmchairRVer
Los Angeles, Santa Monica
Wannabe-go
Second battery, off-scooter charging
good luck
Les
Inverter works for me. Another thing, if you have a mobility scooter where the battery can be charged both on and off the scooter, you can get a second battery and always have one filled up just in case.
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
We charge ours through the inverter - keeping batteries charged via our solar panel - the secret is to top up as needed or when you have spare battery power and not to let it run too low before charging, otherwise it will drain too much at once from your onboard batteries.
Nigel and Pamala
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
can I add to this advice
Nigel and Pamala
If I may add to this advice.... scooters have various size batteries amp wise..... normally they are paired to produce 24v on bigger scooters... some are 40 amps and others are up to 70 amps... so that is a lot of power to take out of house batteries.
I find on my RV it takes out to much and use the generator to send power to the inverter and batteries.... I have found that my two scooters and or the power-chair only charge between 5 amp and 8 amp .. so a run down scooter does need a lot of time to recover.
Bob
