MH won't start (1 Viewer)
Jan 31, 2016
1,902
3,382
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
My Ford Mk7 based Hymer won't start, we were going out this weekend, but not now.
The dash lights come on for all of a few seconds, the dial needles flicker then everything is dead. If I turn key to start then I get some clicking from under seat and dash and also a strange mechanical type noise from behind the dash.
I've charged the battery but it makes no difference.
Any ideas ?
KeithMak
50
32
South West
none
Check all connections to the battery (clean and tight)
Check all connections to the starter motor (clean and tight)
Check earthing strap from battery to vehicle chassis (clean and tight)
Check earthing strap from engine to chassis (clean and tight)
two
Aug 4, 2011
4,906
4,578
West Midlands
A-Class Fiat
First instinct is the battery. Can you use jump leads from a good one?
When did you last use it and was it fine then?
Has anything been done since the last time used? I always try to look back at the most recent changes/incidents as they are very often the cause.
MikeD
3,936
3,697
London
IH PVC
How old is the battery? It definitely sounds that you are losing some volts somewhere.
I suspect the noises from the dash are relays clicking in and out but you are not getting enough current to turn the starter motor.
TJBi
169
80
West Midlands
Since 2014
As you indicate that you have charged the battery (and presumably then checked the battery voltage?), it would appear to be a issue with a connection.
Looking on the bright side, the Transit Mk.7 is usually extremely easy to steal; until sorted, this issue will make it very difficult for thieves!
Silver-Fox
9,281
29,243
Cheltenham Spa
Rapido
im a not so newbie
My money is on the battery or the terminals with a poor connection.
Just because the battery has been charged doesn't always means it in good condition.
