Mercedes heated mirror switch - which way is off (1 Viewer)
FJmike
972
1,046
Swindon
over ten years
On a roll after getting my aux. heater to work I thought I would have a go at figuring out the heated mirror switch. My van is an Aclass Pilote on a h Mercedes base so I does not have the standard mirrors, switches or heaters. The rotary heater switch next to the mirror adjustment switch has four positions, each of which I have tried and each warms the mirrors (photo below). I have had the van from new (nine years) and never been able to suss this out and have put up with warm mirrors even in the middle of summer, anyone any idea how to turn the heater off?.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I can't imagine why you would need a 4 position mirror heater switch - I'd have thought ON an OFF would be enough.
I'm more worried by the state of that dashboard. Is it meant to be like that?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I suspect there isn't an Off just ign controlled with variable heat settings 1.2.3.4
FJmike
FJmike
972
1,046
Swindon
over ten years
To the left of the photo below the hex bolt is a cover for the leisure battery compartment.
It may not look pretty in the photo as I have yet to adjust it properly after fitting two new Varta batterys and it hardly notices as it's way below knee level so not part of the dash.
FJmike
FJmike
972
1,046
Swindon
over ten years
Like Tony I can't get my head around heated mirrors with four settings, overkill or what
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Wire cutters ..will switch them off in summer then just twist them back together for winter. .switch is not necessary..simple's. .lol
Emmit
8,034
17,753
Cornwall
Pilote Explorateur
Jan.2014
Just a thought. Would you notice the drain on the battery if you connected a multimeter across the terminal on the battery.
FJmike
FJmike
972
1,046
Swindon
over ten years
I would expect a drain on the battery but as the heating elements are powered by the cab battery, which is well stowed away under the floor I haven't bothered to check.
FJmike
FJmike
972
1,046
Swindon
over ten years
As an update. After having another look the switch I was wondering about has nothing to do with the heated mirrors it is a switch for a travel heater that blows back into the habit. area. So I have to assume that the heated mirror don't have a switch.
