Mercedes 310D Motorhome Vibration over 40mph! (1 Viewer)
Josh and Kate
5
Northumberland
Mercedes 310D Elorcruise
Couple of years
Hi there,
New to the forums, all advice welcome.
We have purchased a Mercedes 310D Elorcuise Motohome 1994, very solid chassis needs a bit of TLC on body and internal.
When we drove it home when we went over 40mph it began to vibrate, my ignorance made me think of the uni joints on the propshaft or play in the propshaft, but all fine.
Help!
Thanks in advance
Josh
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
Hello and welcome! :WelcomeFlag:
MikeD
3,936
3,697
London
IH PVC
Since 2012
Hi and welcome to the Fun. :)
Wheel balance?
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
Tyre check
balence
a bulge
broken bands in the canvass= tyre miss shaped after kerb img or rutt hole
TheBig1
17,630
43,279
most common cause of the vibration over 40mph is a damaged tyre, a tyre out of balance or a buckled wheel. an out of balance propshaft or uj would be there at all speeds getting worse with speed.
with an older van like yours my first instinct is the tyres may be older than 5 years and despite good tread may be delaminating and splitting
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
It might be interesting to know the age of the tyres, look for a date mark, week followed by year of manufacture, regular comments on here regarding age of tyres / replace every 5 yeas or so
Look for marker like this
can be confusing as in first example, but will give week of manufacture followed by year of manufacture (y)
it can however end up on inside of wheel when fitted so you may not find it easily
J
Josh and Kate
5
Northumberland
Couple of years
Hey all, thank you for all the replies and welcomes. The culprit seems to be the center bearing on the propshaft. Any one have any ideas on the cost for refurbishing the propshaft and the center bearing, approx?
I am able to take it off and take it to a specialist. Just wanting a rough idea on the cost.
Kate
TheBig1
17,630
43,279
many years since i had a propshaft refurbished and balanced. but i would expect £300+
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
While you have the propshaft off, you should get the UJ's changed too. Don't know the cost but I would think 3 or 4 hours work plus parts. So, the cost shown above wouldn't be far out.
unimog
37
44
In the doghouse
Mercedes unimog 1300L
2 years
Most of the Mercedes vans of that series have swagged uj joints and not changeable but the centre bearing are easy to fit . One half of the prop is a press fit into the bearing and has a internal spline into which the other half of the prop fits. If the uj,s are worn I used to machine the weld off and remove the whole assembly and fit a new yoke uj and flange . There are plenty of firms who advertise in the Commercial motor who do this type of work and will also supply centre bearings . Mercedes prices used to be eye wateringly expensive . Mike
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
PM/message/email me your VIN number and I'll advise part numbers.
The centre bearing is replaceable without changing anything else, it is often the rubber mounting perished rather than the bearing itself.
I have the Mercedes EPC Parts system on my laptops.
Peter
