Maxview signal booster no power (1 Viewer)
joecarter8
4
Autotraio F72
I have a new Autotrail F72 with a Maxview signal booster which has lost power. (12v and mains working for everything else)
This may be a loose connection but can someone advise what fuse this would be connected to as I can’t find it labelled anywhere.
Thanks in advance for any help
Apr 6, 2019
3,787
7,500
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
I have unscrewed a cover before to find a fuse inside on old model and a loose wire in another.
Feb 22, 2016
3,637
10,944
York
Bailey 620 Approach
On our 2012 Bailey, the fuse was the 10amp marked AUX Socket.
joecarter8
joecarter8
4
Autotraio F72
Thanks for the assistance, I found the issue whilst unscrewing the in coming coaxial - an internal water feature and booster full of water. No wander I haven’t been able to get a tv signal!
Sep 3, 2023
6
South Wales, aberdare, UK
Adria matrix
8years
I have the same problem just found water coming out of the coaxial cable, water only in the sealed unit inside the plastic cover. I presume the water is getting into the coaxial down the metal aerial antenna???
Oct 18, 2022
1,374
5,600
South West
Adria Twin
Since 1992
Similar problem with an Avtex antenna, luckily no obvious leak into the van, but metal (copper?) shield inside coaxial cable corroded and crumbling.
CGautoT
AUTOTRAIL
This appears to be a common problem have an autotrail F60. 1yr old
Been told by the dealership, today, the booster had failed due water down the coax, it's a common fault and. Autotrail are aware of it. They are looking to Autotrail to replace the whole aerial system.
