Maxview outside socket (1 Viewer)
Welsh girl
3,658
3,036
Globecar
Since 2004
I'm trying to get one of these off our outside wall to reconnect the satellite wire to the receiver inside.
How does it come off please?
Ive taken the screws out but it won't prise off.
Any ideas please?
A previous owner used the inside socket to have a connection for the roof aerial.
We want to use it for an outside freestanding dish.
TheBig1
17,630
43,324
They come with a foam gasket but people tend to sikaflex them on to prevent leaks. it comes with the cable already attached, so you need to trace the wire inside the van and free it off before removing too
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
When I took the screws out some sealant came with the screws so they may have sikaflexed it on as you say.
We've found the cable coming inside but it's going to a splitter to the freeview box installed already within the cupboard that autotrail have fitted in the factory.
TheBig1
17,630
43,324
with sikaflex the only way to remove it is to cut through it, which will destroy the plastic part
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
If you can access the inside cable why do you need to remove the box?
I've accessed the cable. It was going to the freeview box. We thought there wasn't a satellite cable there but it's all done now. Thanks for the input
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
There's no electrical difference between 'satellite' cable and 'TV' cable apart from satellite cable is lower loss. If the run is more than a few feet satellite cable is essential for satellite reception. If it's only a short distance (which it always is in a MH) and TV cable already exists it will work fine for satellite reception.
