Making the change from lead acid to lithium - a thread with pictures (18 Viewers)
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
First battery, decided to weigh it.
It is lighter than advertised, or my scales are out a bit. 12.9kg.
Dec 2, 2019
3,632
7,847
Amersham
van conversion
Since 2019
13kg is pretty much average for a 100ah er. Varies a bit o components padding strapping and the case.
53,895
151,820
First one is in. Just need to shorten the cables now I know the layout of the battery terminals and where they are.
Fits perfectly!
I would use something better than camlock straps they always work loose under vibration. I use them to hold my bikes in place in the garage they are always working loose.
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
I did wonder if they were the right answer.
I have used them to carry kayaks for years and some of them do come loose. These seemed to be okay, I will cable tie them as well through the fabric so I know for sure and a quick snip will release them.
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
The temperature sensors are connected up and on the negative of the battery I think will get coldest.
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
Will post an update when I have had chance to use it.
A huge thanks to all those who have helped. I really couldn’t have done it without your help. 👍
JockandRita
11,499
150,447
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Googlebot. I know I've not been able to contribute to your excellent install, (apart from the ally jump leads bit 😉 ), but I have thoroughly enjoyed your detailed blog, complete with images.
Great stuff thanks. 👍
Hopefully, (having also installed a B2B in November time), we'll both be able to test out our installs properly in the Spring. 😉
We have 4 x 80A Gels, which I would hope to replace with 2 x 100A - 150A Lithium's, so will be keen to know how you get on with yours over time. 🙂
Cheers,
Jock. 🙂
BDM
Aug 17, 2013
155
199
Norwich
Since 2008
Good job, thanks for sharing. Could I ask whether you grounded the Phoenix inverter?
Jun 10, 2010
8,584
20,374
Shrewsbury (sometimes)
N&B Clou Liner MAN
I've used them for years on my Mower battery without an issue. I think the difference is that bikes move and kayaks flex whereas a battery is a brick.
Jun 10, 2010
8,584
20,374
N&B Clou Liner MAN
Only if you want really light cheap jump leads for wiring. 😢😂
IMO you should stop beating yourself up about it. Its a nice neat job and should be a big improvement. Extend your right arm, reach over your shoulder and pat yourself on the back for a job well done (y)
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
Cheers,
Jock. 🙂
I know, roll on spring and hope the vaccines work!
I haven’t as it is purely to plug stuff in where it sits. I was thinking of putting a changeover in but that would involve changing the consumer unit and an auto changeover. I can’t justify the hassle and cost.
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
Inverter is fantastic!
Does not get hot and cables stay cool too, chalk and cheese compared to the old one. Decided to try it with 1500 watt to see what would happen. The old one just shut down.
The Victron is more robust and just drew more amps to match it, though I am sure it would eventually shut down.
Alas the 100amp mega fuse went with a pop!
Will change it for a 125amp one, I don’t really want to be drawing any more than 100 amps as the cable is only rated for just above that so I am happy to see how I get on.
The lithium are sucking up the electricity too, been on the full 18amps from the EBL for 6 hours now, never seen the lead acids do that.
53,895
151,820
EBL may not last long, you could buy the additional unit that plugs in to the EBL doubling it to 36 amps. But for that much money you could buy a decent charger with a Lithium profile.
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
EBL may not last long.
I was worried about that, given even a repair is more than a dedicated charger, do you think it’s worth biting the bullet?
How would I disable the charging on the EBL, is there an easy fuse to pull?
Good grief, what were you running to blow a 100A mega fuse? :whatthe:
Cheers,
Jock. :)
Fan heater, I wanted to see what current it would draw at 1500 watts. More than 100 was the answer.......
Googlebot
Sep 29, 2019
3,079
7,116
Hymer Exsis
20 years
Yep, a 20amp fuse on the front panel.
Thanks Lenny, will see what happens when they are full.
I don’t tend to be on hookup all that often so I am hoping it will have an easy life. Ecotree did warn me they would be fairly discharged, they were quite right!
