Mains unit cooling fan woes (1 Viewer)
Apache
497
644
Rotherham
Coach built
5 Years
The cooling fan on our mains 'Box of tricks ' which manages 240 volts , media unit etc seems to run a lot more than I would have expected, ie it switches on after only having been connected to mains for a short time then cycles on and of until I disconnect the site supply. Is this normal ?
It's on my autotrail apache by the way.
Also the control panel above the entrance door shows a green light when I first switch on the 12 volt supply but then goes straight to red. I suspect these two things are related
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If the red light means the 12v system is over-loaded try removing fuses or switching off breakers for the 12v systems. If the red light goes to green after doing this replace each fuse or switch on breakers one-by-one until you get the red light. The circuit that makes the light go red is the problem.
If the red light stays on after you have disconnected all the 12v feeds check your leisure battery or batteries' voltage.
Apr 9, 2013
663
373
Ayr
Newbie
I suspect your battery voltage is dropping too quickly, probably just knackered, which is making the mains unit work overtime as it tries to charge it back up.
Do you have a multimeter?
Tim
tonka
10,833
21,531
Cannock, Staffs
A class Burstner 800
Since 2000
As above.. Contact Sargent, very helpful and they also off a fixed price repair if needed..
My friend had an issue with his EC325 unit and had to send it back. Repair / replacement was back in less than 5 days..
