Macerator hose length (1 Viewer)
X
Xoxoc
How far can the flojet RV macerator pump it's contents using 1" corrugated hose (not layflat)?
I have 25 metres but thinking of getting more but don't want to waste my money if the pump can't handle it.
TIA
Bryan
Jim
Ringleader
Jul 19, 2007
36,417
130,897
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I have 4 x 25m lengths i bought from Duncan, I have used 3 together no problem, but gravity was helping a bit.
I have got a spare 25m of unused roll flat, complete with fitted clips, yours for £25:Smile:
X
Xoxoc
Can you attach/send me a pic of the clips so I can see if they are the same as mine :Smile:?
Pammy
Aug 3, 2007
881
152
Mansfield
AUTOTRAIL CHEYENNE
3 years
TIA
Bryan
You dont have to pump it home Bryan, they have dumps in Spain:RollEyes:
Ps IMHO lay flat of any legth will reduce the distace you might get with round hose
100 meters is the max me thinks with round house But please remember when your tote is full, you still have a 100 meters worth in yer pipe:ROFLMAO::ROFLMAO:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
43,329
49,444
scotjimland
2,324
10,061
A Woosh bang
tried again
using 12.5mm radius
and 100 mt length ( height )
= 10.79 imp gals
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
Well I just went outside and filled 100m of 1" hose with water and emptied it into a bucket, and I make it 11.154 gallons give or take a drop.
I am flipping freezing going indoors now. ::bigsmile:
Olley
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Olley
That is what they call dedication to a cause :ROFLMAO::ROFLMAO:
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
No, thats what they call bu**shite :ROFLMAO:
3.1415x.5x.5x3937.0078-277.4195=11.145 gallons of shite
Area of a circle is Pi r2
Inches in 100 metre=3937.0078
An imperial gallon=277.419547 cubic inches
oop's looks like I transposed the 4 and the 5 in the last post. :Blush:
Olley
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
None of you so called mathmaticians have asked
Is the pipe internaly smooth or ribbed:Blush:
and internal rib will reduce the surface area severly reducing content volume :Doh:
Amatures:RollEyes:
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
I based my calcs on layflat, no ribs ::bigsmile:
my maths teacher wouldn't have called me a mathematican, thicky is more what he would have called me. :ROFLMAO:
Olley
scotjimland
2,324
10,061
A Woosh bang
Well, if we are getting all technical ..
the distance a macerater can pump is dependent on three factors.
* Pump output pressure.
* Hose Diameter.
we have seen that a 1" hose holds aprox 10 gal , that weighs 100 lbs , a 1/2" diameter will hold much less, so for the same pump output the distance it could pump would be greater, probably nearly double that of 1"
* Hose Type
Smooth bore is best, it offers the least resistance to the flow.
Convoluted offers greater resistance than smooth
Layflat is smooth but requires pressure to open it so the pumping distance is reduced , by how much ? I will leave Olley to do the testing :roflmto:
Summing up .. 1/2" smooth bore garden type hose will give the longest pumping distance.
I used 30mts of 1" smooth bore, clear, reinforced, flexible nylon pipe, being able to see what was happening (or not) was a definite advantage ..
