Lunar Roadstar 720 Power
Discussion in 'Tech/Mech General' started by Bilbat, May 16, 2015.
  1. Bilbat
    Bilbat Funster
    Oct 10, 2014
    20
    22
    Solihull
    Hi. I hope someone can help. We went to bed last night, everything working ( electrically) but when we got up this morning none of the habitation lights would work and no power to the wash room. The fridge was working (lights on), the water heater lit & the step works. The panel above the door is showing about 6v on both batteries but the batteries are showing 12v+ when checked with a meter. The engine starts fine. The lights did start to work while I was messing around with various bits and pieces but then stopped working again. I don't know what I touched. We've packed up & come home now as it would be no fun sitting in the dark with no pump, lights etc. As I said, I hope somebody may be able to help.
    Bilbat
  2. ebo
    ebo Read Only Funster
    Nov 9, 2009
    65
    56
    Essex
    Don't know what power supply or control panel you have, but I've had a similar problem with my Lunar Roadstar 800 which has the psu2007 & EC200 control panel, I took off the control panel removed the data cable to it, put it all back & it all worked fine again, this has happened several times now, so expect problem with control panel, maybe the same for you.
  3. Bilbat
    Bilbat Funster
    Oct 10, 2014
    20
    22
    Solihull
    Thanks for the reply. It's fitted with a CMS 2000 control panel which nobody seems to know who makes it. I wouldn't know which is the data cable and don't want to mess too much with it.
  4. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    try unscrewing the panel and just dusting/blowing behind it. Your panel is a little different from ours, but it worked for us xxxx
  5. Bilbat
    Bilbat Funster
    Oct 10, 2014
    20
    22
    Solihull
    Hi everybody. I went to Jacksons yesterday to get some names of people to look at this for me. One of the engineers was there so I asked him. He said its more than likely to be the battery. I hooked up my battery pack but it made no difference. I rechecked the fuses and the lights came back on. Looks like its just bad fuse connections. So I shall try cleaning all the connections at the weekend and hopefully that will cure it. Thanks again for your replys.
    Bilbat
