LPG fillpoint location . (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
how does the weight of the filler and hose decrease as it gets lower? surely the bending force exerted by the weight remains constant?
In the skirt the hose is on the floor and takes the weight of the nozzle
Imagine a cobra poised
High up the nozzle has to carry the weight of the hose as well
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Our skirt mounted fill-point is not as low as the waste water drain and refilling with gas is not as regular as emptying that.. Also, as Techno says, most of the weight of the hose is on the floor.. Our skirt hardly flexes when connected to the gas re fill nozzle. Remember, the skirt is supported inside (a) By the skirt support strut and (b) by the hose that goes to your bottle/s...
My only problem was the "arsewinkey" experience of drilling a 70mm hole in our brand new van !! But not a single regret since.. (Fitted Gas-it)
Good luck with whatever you decide to do.. (y) Mitch..
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
i have mine fitted in locker saves cutting a large hole in side of van,only told once i shouldent be filling that way but got he gas any how[should have said that was in france]
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Of course if the UK didn't insist on supertanker hose & a nozzle that takes two to lift it it wouldn't be an issue. The French filler is an elegant piece of kit.
Cossieg
221
98
Yate for the summer!
None now
Is the skirt area really strong enough to take the filler point with the weight of the nozzle/hose connected to it? On my Autotrail the skirt is a flimsy plastic affair that I wouldn't fit anything to!
colinw
colinw
523
306
Bolton , Lancs.
low profile
Under a year
Hi cossieg , the skirt is metal and I will fashion a support bracket to steady the fill point . thanks for the warning though , all input is gratefully received as I am a complete m/h novice . I still have to go and look at an LPG filling station to see what is involved when filling up though to satisfy my worries about the height off the floor .
colinw
colinw
523
306
Bolton , Lancs.
low profile
Under a year
Thanks , and all from the comfort of my bed . I can see that there will be some downward force exerted , so the support bracket will be a necessity to stop the skirt being bent .
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Have had filler point inside locker for 5 years, never a problem anywhere filling up.
however, you can now buy a hose where one end screws into filler point, and the other onto external gas bottle. Easy peasy when set up for a while or overseas with different gas bottles.. Will consider moving my filler point for this reason.
Theonlysue
6,104
7,383
Essex
Not long enough!
LilacMoss
384
2,251
South Yorkshire
Looking again....
Im a newbie...since Sept 14
@ScotJimland Thanks for the clips! (y) Took my moho to put lpg in the refillable gaslow bottle for the first time this week...and came away unfulfilled. :whistle:Couldn't work out how to connect the hose and neither could I lift it either. Im very aware look young & healthy but I have invisible conditions that means I have no strength or dexterity. Methinks I may have to work more on my smile and feminine charm to get help with a refil...:makeup::giggler:
scotjimland
2,324
10,065
A Woosh bang
really.. ? This should result in some interesting comments ..
(fetching coffee and bikies , brb )
Techno
Jul 28, 2010
15,475
20,756
May 2010
on the skirt is fine... but how is it in practice.. ?
is bending down low to fill , particularly on a wet day, going to be difficult if you have problems with your legs or back ?
just a thought..
I took the opportunity today to take a photo as it always says far more than words. My fill point is only just below my knee and as you can see there is realistically no weight on the skirt as the fill hose is largely supporting the connection.
I must add that this arrangement is far superior and user friendly than inside a locker for those who advocate that :LOL:
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Fitted mine to the skirt twice now.. When I removed it from the miller I spent £2.90 on a blanking plate where it was.
colinw
colinw
523
306
Bolton , Lancs.
low profile
Under a year
If there was any flex on yours techno I'd be disappointed ! . that's how mine looked when my chap filled mine and mine doesn't have a strengthening support like yours .
Again a great pic to help any future installers , thanks .
Lenny HB
53,430
149,982
On the coast in West Sussex
Hymer B678 DL
You often find the outer collar on the filler nozzle is not fully rotated back to the stop, without it in this position there now way you will get it to connect.
It is a lot easier if two of you do the job as often the locking clip on the pump leaver does not work or is broken, one can hold the nozzle in place and the trigger while the other pushes & holds the button on the pump.
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
Thats why I went inside locker. Simple right angle sheet fixed to bottle slide, carries filler. Allows spare 6kg bottle to fit behind, not got round to fitting BBQ point yet.. Fully removable if we change van.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I hope I didn't read above that the OP has contemplated fitting the filler and pipe to a part of their MH open to the interior?!!!:Eeek:
