Low watt ? (1 Viewer)
Kevingrc
122
45
Burnley
Majestic 155
I'm a newbie
Sorry I'm back again,is it recommended that you use low watt electrical appliances and are there some that just don't work as good and not worth getting ?
43,329
49,446
Do you mean 12v or 230v ?
12v kettles and hair driers etc....keep your money in your pocket...worse than useless.
230v low wattage kettles etc will work fine albeit a bit slow compared to your kettle at home.
1kw should be ok for a kettle and hairdriers should all be ok....but not at the same time depending on hookup amperage.
tonka
10,833
21,531
Cannock, Staffs
A class Burstner 800
Since 2000
My view findings on camping and low power.
If products are around 1000w and MAX 1200w then they should operate from a 6amp supply.
6amp seems to the default supply on older campsites, some aires and sites that really want to restrict supply when it's included with the price.
2,747
9,575
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Top of the list to buy, Remoska oven from Lakeland, a 2 litre slow cooker.
Invaluable for excellent meals with minimum of effort.(y)
911
661
Cotswolds
Bailey Approach 625
Since 2011
We have three 800W items that work a treat on our 1500W inverter, one at a time of cause.
A hair dryer, said to be like ours at home on the low setting, I don't use it be Linda says its acceptable.
A cheapo two slice toaster used occasionally.
But used most of all, like several times a day is our travel kettle. Its holds 0.7 litres which perfect for our two large mugs of tea/coffee, hot chocolate. It takes 6 minutes to boil, and takes 75Amps from the battery. As 6 minutes is tenth of an hour, it uses say 8AH from the battery which the solar panel regularly replenishes in around an hour. We have had our setup for a year and seem spot-on for us.
whoa
295
5,566
West Yorkshire
It's been sold, no more
I'm a newbie
Another vote for the Remoska at 400 watts, using it often at home in practice for when we finally get the MH and up up and away
43,329
49,446
Or 580watts for the 4 ltr version.
Not exactly a slow cooker but a compact oven.
Cooks a whole chicken in half the normal time.....including a crispy skin
roast spuds....no prblem.
Anything you can do in a conventional oven can be done in a remoska....including cakes and bread rolls.
18851_1
whoa
295
5,566
West Yorkshire
I'm a newbie
Ours is the standard or smaller of the two, I didn't want to slightly deviate the thread but apart from a couple of recipes there is one the the manual States about page 3 slice some spuds, onions and carrots, place in our case 2 chicken legs on top, drizzle with olive oil, salt and pepper, and cook for about an hour in our case, last 20 minutes add 200 Mils of chicken stock, wonderful flavoured gravy, and oh yes the crispy skin, yummy, haven't had that for many a year but I am now
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
We have a small kettle and two slice toaster both are 1350 watts each. Inverter friendly
whoa
295
5,566
West Yorkshire
I'm a newbie
We've also got a slow cooker, but not sure if we will be taking it with us, got a 2.5 litre pressure Cooker which although used On the gas, can do a lot of stuff
2,747
9,575
Chester
Auto-trail
Easy one that, pressure cooker = loads of steam, slow cooker no steam just lots of yummy aromas, plus it`s electric, so not using your gas.
paulmold
892
302
North Wales
7 year (25yrs a tugger)
Don't get conned into buying a special low wattage toaster. One labelled as a 'caravan/motorhome toaster will probably be around 800w and cost around £16/20. basic domestic toaster from Argos same wattage costs £4.99.. Basically anything with the word 'caravan' in the title eg toaster, kettle, microwave will cost more than double the same wattage household appliance.
paulmold
892
302
North Wales
I got it wrong - it's even cheaper !!!! £4.49 in Argos
Broken Link Removed
