low suspension MOT failed on 630L
Discussion in 'Tech/Mech General' started by MNP, Jan 11, 2010.
  1. MNP
    MNP Read Only Funster
    Jan 11, 2010
    3
    Hi,
    We brought a new Swift Sundance 630L on Fiat base in 2006. We've had an amazing 3 years touring.
    The 630L has just been for its first MOT after 3yrs & failed due to low clearance of back suspension.
    Would love to hear from anyone else thats had similiar troubles or heard of any.
    I have always been aware of the large overhang & tried to pack weight accordingly, however we do have a bike rack & bikes on the back which no doubt adds to the weight.
    The Motorhome is currently fully unloaded (including water,waste tanks) but still the technical clearance is not even close to passing on our 3 year old vehicle.
    Our mechanic has recommended changing leaf springs in the hope that this will correct the clearance but he cannot be sure that it will.
    What other options are out there? Is the air suspension a possibility in this case?
    Mac
  2. coroner
    coroner Read Only Funster
    Nov 23, 2008
    41
    clearance
    I would look at fitting air suspension do a search on here forit a few people have it fitted
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi Mac,
    As Coroner has mentioned, air suspension should sort your problem, giving you the added advantages of adjusting ride height according to loading and decreasing body sway/roll.
    I am looking into this myself.All springs lose some of their tension after time.Replacing the leaf springs would be an option but may only defer the problem for a few years.
    I am surprised the rear has dropped so much after only 3 years.:Eeek:
    When they say low, do they mean it's sitting on, or near the bump stops, or general road clearance compared to new?
    Steve.
  4. Neckender
    Neckender Funster
    Oct 15, 2007
    1,440
    1,721
    Neckend or Benidorm
    I fitted MAD spring assistors in the 90s to a Citroen c25 and they lifted the rear 4" (100mm)
    I think the company is still trading.
    John.
  5. estcres
    estcres Read Only Funster
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
    We had our Air Suspension fitted by AS of Warrington in Cheshire.
    Wonderful service, very helpful, can't fault them
    It wa quite expensive but in comparison to the cost of leave springs etc, it must be a very reasonable alternative.
    We can raise our back end by up to 6" on a good day. (No dirty comments please funsters)
  6. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    I had air ride assistance fitted last September and it not only gave the option of varying the ride height at the rear, but made the "Van" a lot more stable for cornering and on the Motorway :Smile:
  7. ginge61
    ginge61 Read Only Funster
    Oct 29, 2007
    431
    n/wales
    go to another mot station :thumb:not heard of a failure like that before
  8. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    There is someone on here who will I'm sure know the answer. :BigGrin:
    Where's Geo when he's needed?
  9. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    197
    5
    Lanner - Cornwall
    Hi There,
    After purchasing my 1996 Fiat Ducato 2.5TD based Hymer with garage back in 2005 specifficaly to carry my wifes disabled Battricar and a small moped,which came with Airride fitted as a Factory Extra and looking at the single Rear spring I went down the road of up rating the springs by adding two extra leaves. I removed and fitted them myself with the assistance of a neighbour but the cost was £300 to modify. The ride was always level but a lot firmer and you do get more road noise but I felt safer, alright tongue in cheeck I was probably overweight but at least it looked okay to those people that matter.
    Hope this helps in some way
    Brian
  10. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,896
    6,157
    Mansfield,Notts
    Section 2.4 Suspension General
    Reason for rejection 1. Inadequate clearance of the axle or suspension with the bump stop or chassis,
    A suspension unit so weak that the body or other part off the vehicle fouls a road wheel or would do so when fully laden.
    It would be easy to say pass and advise, but only the tester concerned can make that judgement.
    Note missing bump stops are not a reason for rejection
    So take em off-----sorted:Doh:
    Geo
  11. MNP
    Jan 11, 2010
    3
    Hey,
    Thanks so much to you all for your very helpful advice. Overnight ive had to become an expert on suspensions from yesterday not knowing a thing but now understand that the 2 most common types of suspension springs are leaf and coil.
    So yes one side at rear was touching the bump stop which is not good for a 3 yr old vehicle, in the 630L the design does lack as most storage is over back axle with very little storage near front.
    I have decided to go ahead with the obvious choice of air suspension supplied by www.airide.co.uk costing £470+shipping.
    Cheers heaps everyone
    Mac
  12. ingram
    ingram Read Only Funster
    Aug 9, 2008
    87
    I'll just add to this because it is known that the Ducato ( and siblings ) suspension has a 'bump stop' which is actually part of the suspension and it is normal for a fairly small clearance to exist between the bottom of the 'bump stop' and the top of the leaf spring.
    I have seen this discussed on / in other forums and mail lists and also seen it, with photographs in one of the Motorhome magazines ( can't recall which though )... so it may be a good thing to fit air assist suspension but it *may* not really be necessary ....
    Harvey
  13. wayfarer
    wayfarer Read Only Funster
    Sep 27, 2007
    125
    Co. Clare. Ireland
