lost all hab power (1 Viewer)
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
hi we seem to have lost all hab power the battery's are fine thought they were knackered but had multy meter set wrong.
there is power going to the board controller but it dose not seem to light up thinking it has dyed
D
Deleted member 29692
Is there a fuse somewhere protecting it?
TheBig1
17,630
43,279
check at the switch on the board. if you get power through from engine battery, its either a bad connector on the wiring from leisure battery or battery itself dropping under load
Wildbill
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
I have 12.9v at zig unit
Wildbill
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
I have had problems with this from time to time wondering if I should just re wire the hab aria of the van only x six lights water pump and fire fan and just have every thin on fuses
bill
TheBig1
17,630
43,279
on which wire bill, the leisure or the engine battery? does the 12.9v appear on the output of the switch?
TheBig1
17,630
43,279
it should be an easy(ish ) fix if its a dry joint or bad switch
Wildbill
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
b
getting pworer both from starter battery and leisure battery
Wildbill
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
I now have power to the hab aria but the zig controller dose not light up or switch over from bat 1 to bat 2
TheBig1
17,630
43,279
i would suggest its a bad switch then bill
dry joint is a solder joint that has failed and needs resoldering
Wildbill
Nov 18, 2011
11,862
43,027
Planet Earth
A van
Over 25 year's
I have had problems with this and the transformer for a while I have disconnected the trans former and fitted a maintenance battery charger
as I cant get hold of a trans former
