For Your Information. Enjoy.
Until the world runs out of it..Lithium is better!
Real positive vibes your putting out there Marvin ??Until the world runs out of it..
Lithium won on price / lifespanHaven't got fifteen minutes to watch it so what is the result?
However they didn’t take into account the weight / space benefits
They didn’t take that into account either.Weight and space are great, but in real world use it's speed of charge for me
Sorry to burst your bubble, do some research about what's involved getting it out of the ground, it's not the wonder material it's made out to be.Real positive vibes your putting out there
If they were mining Lithium in the EU it would have been banned years ago.Sorry to burst your bubble, do some research about what's involved getting it out of the ground, it's not the wonder material it's made out to be.
Anything to do with the EU is always banned, it’s just a way of life??If they were mining Lithium in the EU it would have been banned years ago.
Neither is lead. The mining and smelting of lead has serious environmental consequences too.Sorry to burst your bubble, do some research about what's involved getting it out of the ground, it's not the wonder material it's made out to be.
Lithium batteries have a battery management system which controls charging at very low temperaturesI'm more concerned with how temperature affects the lifespan.
This last week in Scotland the temp has struggled to get above 4 degrees during the day and down to -2 at night.
How does Lithium cope with that over an entire winter (or worse).
Graydo
The battery management unit won't allow them to charge if it's too cold.I'm more concerned with how temperature affects the lifespan.
Graydo
But what if it's not charging,Lithium batteries have a battery management system which controls charging at very low temperatures
You do exactly the same as you would when your water tank gets cold... WARM IT UPThe battery management unit won't allow them to charge if it's too cold.
So if it's too cold and they are too low to start the heating and you are relying on solar to charge them you are stuffed.
I doubt if you would actually get into that situation in normal use.
The world will run out of everything eventually so what's your point?Until the world runs out of it..
The battery management system stops charging when too coldBut what if it's not charging,
i.e in storage?
Graham
Very clever reply... that'll make everthing ok then..The world will run out of everything eventually so what's your point?
Ever heard of that little word called RECYCLEVery clever reply... that'll make everthing ok then..
That was my point if the battery is too low for the heating to work your stuffed.You do exactly the same as you would when your water tank gets cold... WARM IT UP
