leisure battery help
Discussion in 'Motorhome Chat' started by alsmith, Feb 7, 2012.
  1. alsmith
    alsmith Read Only Funster
    Feb 7, 2012
    5
    oxford
    I’ve got a j-reg t4 trident camper that’s fitted with a zig mc2000 unit.
    For some reason it has stopped working ,i.e. no power to socket, lights or water tank tester.
    I’ve checked the 6 fuses on the unit and they all look ok. plus the fuses on the charging unit.
    I plugged it into mains last night hoping this would charge the battery up but to no avail, the lights this morning came on for half a second and went off again.
    Is this down to the leisure battery possibly being faulty or would there be another problem??
    I’d be very grateful for any advice or hints as to what the problem could be.
    Many thanks
  2. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,984
    2,780
    Englishman in Mid Wales
    Hi and welcome to fun:Smile:, I'm no good to you I'm afraid but I'm sure someone will be along soon to help you out:thumb:
  3. alsmith
    Feb 7, 2012
    5
    oxford
    cheers wizzer
  4. hilldweller
    Dec 5, 2008
    27,551
    26,644
    Macclesfield
    The horse's mouth.....
    http://www.zig-electronics.co.uk/products.htm
    Can you find working 240V inside ?
    Can you find the charger, are there any switches you could have knocked off ?
  5. alsmith
    Feb 7, 2012
    5
    oxford
    hi hilldweller
    ive emailed the zig company the same question but had no reply.
    the 240v is working inside the van
    ive checked all the internal fuses and they are fine,also the rcd switches are all on.
    been told it could be the leisure battery braking down inside
  6. lionart8085
    lionart8085 Read Only Funster
    Feb 7, 2012
    wales
    leisure battery help?
    hi, i had a simular problem and i found that there was a weak earth going to and from the zig so i uninstalled it and pluged it into my house, it just blew so i bought a zig cf9b and it was a far more better unit. hope this helps!
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    this cold spell could have seen off many batteries that were close to the end of their life.
    i would disconnect the hook up then the leisure battery and check it with a multi-meter to find out.
    if its below 12 volts its flat and if it has been that way through a frost or 2 then probably wont recover depending on its age and will need replacing.
  8. stcyr
    stcyr Funster
    Apr 11, 2011
    1,681
    1,115
    Normandie
    :welcomefunster:
  9. alsmith
    Feb 7, 2012
    5
    oxford
    many thanks for the info.
    would it be worth connecting another battery instead of the leisure battery just to see if that solves the problem before i go and and buy another
  10. JJ
    JJ Funster
    May 1, 2008
    14,893
    26,701
    Yes...
    JJ :Cool:
    but I suspect it is the battery... Do you have a multimeter? It is a very useful bit of kit...
  11. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    welcome to the forum
    JJ is right.. get yourself a multimeter.. not expensive will allow you to check the mains as well as the battery side of things... Maplins sell them at reasonable prices.
    But you could put a normal 12v battery in to test and see if the power comes back. The old Zig units often failed.. lots of better units now available even from Zig.
    Regards
    Bob, Sue and Ezzie the St Bernard.
  12. upmarkethippy
    upmarkethippy Read Only Funster
    Feb 25, 2008
    364
    81
    Hull
    zig unit
    Not sure which unit we have and if it is the same as yours, but, We had a power surge a few years back and this blew the internal fuse on the circuit board inside the zig unit.
    Opened the unit and changed the fuse, unfortunately the surge had got past the origanal fuse and the unit just fizzed and smoked.
    I hope for you it is the battery, but if it turns out to be the zig unit, we just fited a 4 stage battery charger and disconected the 12 volt side of the zig unit.
    Good luck, oh and Welcome to fun.
    • Like it Like it x 1
  13. hdvrod
    hdvrod Read Only Funster
    Dec 27, 2011
    860
    739
    devon
    I am experiencing the same problem,have just taken delivery of new 110 leisure battery,am awaiting arrival of voltmeter so I can test the zig before I go any further,if the zig is found to be faulty can I replace the zig witha 4 phase battery charger as the cheapest replacement zig I can find is £132,and a good quality battery charger is way cheaper.
  14. alsmith
    Feb 7, 2012
    5
    oxford
    hi all
    many thanks for the replies,we think we have sorted out the problem.a friend of mine has had a look at the relay's around the leisure battery,one of the connectors had come off and the relay itself was all rusted and bits fell of it inside.
    the knackered one was a 24v 20amp one....can we replace with a 12v 30amp or would it better all round to replace with 24v 20 amp one?
