Leisure battery connection
Discussion in 'Tech/Mech General' started by kennygd, Sep 9, 2010.
  1. kennygd
    kennygd Read Only Funster
    Dec 1, 2009
    198
    9
    Anywhere in the UK
    :BigGrin:Good morning all, fairly nice day here in Whitby, my daughter needs to connect up a sceond leisure battery to her Autotrail Scout, is it a straight forward plus to plus and minus to minus connection and does it have to be a special leisure battery or normal vehicle battery ?
    Thank you folks:BigGrin:
    kennygd
  2. welsh winger
    welsh winger Read Only Funster
    Jul 7, 2009
    231
    58
    Sunny Swansea
    In an ideal world the 2 batterys should be the same, ie both the same amp/hour, other wise the the 2 batterys will only charge to the lowest capacity one, people will say fit 2 new batterys at the same time, well yes make sense, but cost can make you think twice.
    In short get a second battery the same amp/hour/type I would not suggest mixing ordinary and leasure.
    in time when one or other of the batterys looses its capacity it will affect the other one as well, in relation to holding a charge, the bad battery drags the good one down.
    hope this helps
    Nick
  3. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,747
    8,661
    Tropical Bar,Benidorm.
    Hi Kenny
    Ideally it should be a leisure battery of the same age and amp/hour capacity of the existing one. Plus to plus & minus to minus is correct, you will need to fit a fuse to each end of the plus to plus lead. Someone more knowledgeable than me will be able to tell you the rating of the fuses and also the size of the wire that you should use to connect the batteries
    Brisey.
  4. kennygd
    Dec 1, 2009
    198
    9
    Anywhere in the UK
    Hello Nick, thanks for that, as far as connections go is it live to live and neutral to neutral or do you know of any special way it has to be connected?
    Ken
  5. kennygd
    Dec 1, 2009
    198
    9
    Anywhere in the UK
    Thanks for the help Brisey
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,928
    1,947
    Warwickshire
  7. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    I had a look at your link and can not see an obvious difference between installing two batteries either in sequence or parrallel. Both arrangements appear to do the same job.
    If there is a difference, what is it.
    Jim
  8. welsh winger
    Jul 7, 2009
    231
    58
    Sunny Swansea
    the differance is between 12 volts for a parallel conection, and 24 volts in sequence/series
    Nick
  9. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    There are two Pink diagrams showing 12V batteries, one in series and one parralel. Both appear to be delivering 12V, the only difference being the connection configuration.
    Sorry, I'm not being intentionally thick.
    Jim
    :Smile:
  10. Lampie
    Lampie Read Only Funster
    Nov 2, 2007
    169
    Derby
    In the drawings ( pink ones ) both are doing the same it is just the drawing on the left is how it would look if both your batteries were side by side ie in same locker. The one on the right is showing how to do it if say one is at the front of van and second battery is at the back of van ie not side by side.
    But it is the pink drawing you want not the ones above.
    Regards
    Lampie
  11. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,928
    1,947
    Warwickshire
    No, the two pink diagrams each show a parallel arrangement (+ to + and - to -). The difference is that the left hand pink diagram shows the wiring and fusing layout to use when the two batteries are adjacent. The right hand pink diagram shows how to wire and fuse the connections when the batteries have to be separated: e.g. if one is under a seat at the front and the other is in a locker. But both arrangements are wired in parallel.
    It is the two grey/green diagrams at the top that show wiring in series; in this case 2 x 6 volt to give 12V output. Again, the difference between these two diagrams relates to battery location.
    For the avoidance of doubt, batteries wired in parallel (+ to + and - to -) give the same rated output as a single battery i.e. 2 x 12V gives 12V. Batteries wired in series (+ to -) give the sum of the rated outputs i.e. 2 x 6V gives 12V.
    What you MUST NOT DO is wire 2 x 12V in series and connect them to a motorhome with a 12V system, as this would put out 24V and blow the system.
    Philip
  12. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Good answer, thanks
    Jim
    :thumb:
  13. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,013
    5,323
    Wirral
