Leisure battery charging.
Discussion in 'Tech/Mech General' started by Stephen Scott, Jul 30, 2014.
  1. Stephen Scott
    Stephen Scott
    Jul 30, 2014
    25
    7
    I have a Swift Freestyle 590 RL Motorhome. 2004
    When I bought it second hand in 2010 it came without a service users handbook.
    Unfortunately I have had problems with the leisure battery from day one and I think this is due to bad advice when purchased. Now on my third battery.
    The electronic system is controlled by a rocker switch which can be switched three ways.
    Upwards shows the symbol for the starter battery, downwards for the leisure battery and the middle position for neutral.
    At the time of purchase I was told that when hooked up I should to put the switch in neutral and only when travelling switch to leisure.
    Was this the correct advice? or is this the reason I seemed to have little charge in the leisure battery?
    Also, can you use a trickle charger to charge a leisure battery whilst it is still in its compartment and connected to the 12 volt system?
    Can the starter battery be charged from the same switch when van in storage over winter?
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,183
    15,159
    Leeds the one up North
    In my experience the battery selected is the one that is in service for the hab and also the one that receives charge when on hook up.
    A separate charger should be fine in situ.
    So you must be careful not to select the starter battery when not on hook up but it can be used in an emergency.
    Check that you haven't got a separate switch for the charger? And that it is on
  3. Sheddy
    Sheddy Funster
    Oct 20, 2010
    938
    4,319
    Burry Port South Wales / Benidorm
    • Like it Like it x 1
  4. Stephen Scott
    Stephen Scott
    Jul 30, 2014
    25
    7
    Hi Techno100 and tremybach,
    Thank you for your quick and helpful responses. I will switch to the leisure setting when on hookup.
    Stephen
