- Oct 1, 2017
- 921
- 1,479
Looking for a little advice from the wealth of experience on here, first weekend away in our m/home, when I called in to pick it up from storage the step wouldn't deploy, when I checked the batteries on the panel it was showing under 11 volts, everything was turned off when I left the van, so is it the case you will always get a little draw on the batteries even when everything is off?
They are fairly new batteries and even if the tracker runs off them (not sure if they do) I am informed it's not enough to use that much, it was only left approx 3 weeks in storage so I'm a bit concerned as it will be another 5 weeks at least before we get to go away again and I don't want the batteries to be completely flat.
Can you just disconnect them to preserve charge?
Thanks in advance
Mark
Thanks in advance
Mark
