Leisure batteries 2 small or 1 large? (14 Viewers)
Aug 19, 2007
560
242
Birmingham
looking
I need to buy some new batteries, for our scotland trip next week &wondered whether its best to buy 2 x 110amp or 1 x 220amp is there any difference or reason to buy 2 instead of one.the 220 amp is slightly more expensive to start with, but 2 would need cables to join them so cost about the same.
these are the choices -
Single http://www.ebay.co.uk/itm/12V-Ultra-Plus-220AH-Leisure-battery-/171945324452?hash=item2808bd6fa4
Pair Broken Link Removed
Any thoughts & has anybody bought instead of two?
Karl
Feb 27, 2011
14,741
76,034
There are a couple of influencing factors in my opinion.
1) Battery failure. With 2 batteries if one fails you have another to fall back on.
2) Battery aging. With 2 batteries they won't always age equally and you may have one pull the other down. This happened to me.
3) Space. Sometimes 2 will fit where 1 won't and visa versa
4) Cost. Price can be a factor?
My personal choice would be a single battery. No particular reason other than experience of 6+ years full timing. I would personally go for the best battery I could afford. Preferably AGM with VRLA valves. But these cost a fortune for good quality. My last batch lasted 8+ years.
Out of those 2 I would pick the single one purely based on weight.. The more lead the better is a fairly good guiding principle when it comes to battery quality.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Is your battery compartment easily accessible? Have you tried lifting a 220Ah battery? The one you are considering weighs 50 kg (not far short of 8 stone!). I could not manhandle that into an awkward location!
C
Aug 19, 2007
560
242
Birmingham
looking
Space is not a problem i have moved the existing battery to under the bench seat, as for the weight i will get help
with putting it in.
Every joint is a point of failure so a single battery wins that argument.
"to under the bench seat" - is it vented correctly ?
Feb 27, 2011
14,741
76,034
My 250Ah batteries were 76KG. I managed to lift them in and out with a little bit of effort. I am a weedy computer geek who hasn't done any physical exercise since his early 20's... That said if you are older and have health issues then weight is definitely a consideration.
I initially have 4 of these batteries to give me 1000AH. Shifting them to a new van did take me a while as I had to take a break after each one :whistle::rofl:
C
Aug 19, 2007
560
242
Birmingham
looking
It was originally under the front seat & not vented as far as i could see, also appears to be sealed with no where to vent from.
I could vent if required to outside.
Karl
Aug 18, 2014
23,786
133,736
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I bet you did !:LOL:
Abacist
3,741
10,744
Devon
N & B Arto 88F Tag
since 2013
What capacity battery is your charger capable of charging? That might influence your decision.
JeanLuc
3,304
2,199
Warwickshire
Respect !!!!!!!!! :eek:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
If I were you I'd get the big Bugger and if I were your bestest mate I'd offer to pop up and give you a lift with it.
  1. I'm not you
  2. Speak nicely to @ROB1CHELSEA1 :moon2: :moon2: :moon2:
C
Aug 19, 2007
560
242
Birmingham
looking
  1. I'm not you
It would cost me more in whiskey get to rob up here than the battery cost, you know what hes like when smells
acohol, may have to bring a trailer for the beer at peterborugh this year.:ROFLMAO::ROFLMAO::ROFLMAO:
That's correct, assuming you have an EBL99 or 100. However, I had 2 x 110 Ah for about 6 years without problem. Now have 2 x 90 Ah.
I have an ebl99, why the change to 90 from 110. ?.
JeanLuc
3,304
2,199
Warwickshire
The 110s were Elecsol - no longer available. Now I have Varta and 90 is their low profile model that fits; less than 200 mm high.
C
Aug 19, 2007
560
242
Birmingham
looking
I did read that you have room, but have you seen they are 200mm longer, they would never fit in my locker (y)
it would fit in one of the the outside lockers( have double floor), but its going under bench seat.
I think your gonna need a 5th wheeler :ROFLMAO: This should do it (y) Broken Link Removed
You could aways drink less !!! :):)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
It would cost me more in whiskey get to rob up here than the battery cost, you know what hes like when smells alcohol, may have to bring a trailer for the beer at peterborugh this year
No...........................................................He couldn't! Be told!
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Mind you making battery connections is not rocket science and 2 batteries gives a certain level of power redundancy. As for venting what would you suggest?
11,842
14,071
I would go for two especially if using an inverter as drawing a high current will be split between them. So for a microwave drawing 150A there will be a draw of 75A from each rather than the lot from a single one. Leisure batteries, unlike starter batteries, are not really designed for high currents.
Thread Hijack.
Going to put one in my mini camper build
Its a slow work in progress as long as its ready for September i am happy. I want a pleasure battery and just using a manual switch but as i only want it for the odd lights at night and a car stereo in the rear would a small car battery be OK? Something around 75amps. I was thinking a Motobatt motorbike battery but not sure if van alternator would kill it.
11,953
16,570
Thread Hijack.
The battery will only accept what it needs - size of alternator has no effect.
I don't suggest anything but I am pointing out that if it is a battery that vents then you don't want the possibility of hydrogen building up in a cupboard with electrics in it as could happen with the post that said "I moved the battery from to........". Some batteries have a vent pipe you can direct outside, some don't.
