LED Strip lights (1 Viewer)
Jan 31, 2016
1,117
606
Halifax
A Class Rapido 9097F
June 2016
Question for those who have fitted LED Strip lights under awnings
Do.you just stick the strip as is or do you purchase an aluminium channel with clear / opal cover and put your strip inside these?
If you use a channel will the cheap 3.59 rolls be okay or will they still melt in heat as I have read?
Also do peeps wire to outside light or drill through and wire to an internal light?
If outside light and using dimmer will the dimmer dim the main outside light as well as leds?
Thanks in advance.
tonka
10,833
21,531
Cannock, Staffs
A class Burstner 800
Since 2000
Mine are just stuck on but do come in plastic like coating, they were only cheap ebay china ones...
Drilled through van and I have the control box for changing the colours / fading etc in there...
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
I fitted my LED strip lights into aluminium chanel which clips underneath the awning box. I wired them into a separate switch and installed a remote control which allows me to dim them (I didn't go for RGB, just white). Here are a few pics:
Jan 13, 2014
3,601
11,585
Leeds - Yorkshire
Can I ask DPSUK999 where you sourced the alustrip with the clear insert,
I fitted mine straight onto the Awning and they work perfectly,however,I have to say your idea is much better and the rail will allow you get it perfectly straight.Thanks
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
If u do a search u will find several past threads on this very subject.
Whilst the roll came with 3m sticky tape attached I used thin body mouting tape as its much stronger adhesive.
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
Hiya,
I used this from eBay:
https://www.ebay.co.uk/itm/322448731425
Came with clips too :)
