LED Fuses (5 Viewers)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
I thought members might be interested in the "led" fuses I have fitted in my MH. These are available in any good motorcar accessory store, in my case I got them sent from UK via father in law who went to Halfords.
The picture below is of standard fuse and led fuse.
To show you the led fuse working I have blown it and this is what you see:
This can save you a lot of time when looking for the "blown" fuse in a confined area were most fuse boxes are.
23,836
72,547
What a good and easy idea..
A question.. are they as bright as they seem to be in your picture ?
Shovelheadrob
60
111
Soon to be 5th wheeler
On & off for 20 years
Does it matter which way around they are? Led's by nature only work when wired the correct way, as in the diode only flows current one way.
23,836
72,547
Hmmmm.. Proly take a pass then ! Mind you, found a load of glow when they blow types on fleabay which seem like a possible option.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Not looked on fleabay, but I would have thought they were the same sort of thing.
23,836
72,547
DOH !! In that case.. All good ! LOL !!!
Fleabay ones seem to start at about £2.00 a set inc postage :)
Shovelheadrob
60
111
Nop I also thought that so tried them both ways makes no difference.
That's good to know, I tried google & no luck there, someone had suggested that they had 2 leds wired in parallel, one in each direction which would make sense.
23,836
72,547
True.. Cannot see them going to the time trouble and expense of fitting them with tiny bridge rectifiers LOL !!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
AFAIK John
That CBE distribution board already has LED's built in.If a fuse has gone and the circuit is switched on then the LED behind the blown fuse illuminates red.
Bottom paragraph
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Andy, this is a new one for me!!! I never knew this and the reason I ordered the led fuses was because one blew and I could not find which one for ages. Now I will go round to MH later and put a blown fuse in and check this out. Thank you for the information.
Heyupluv
3,862
1,593
France,
touring many years..42+
Ours already glow red when blown as Andy has said on our motorhome as standard and on Laneside...both are Rapido's...so many may find they may not need them depending on what age the van is.... also Andy's is a Rapido
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Normal ones flash with a light when they go but you must be staring at them when it happens.
I'll pass on this as the car has 47 fuses and the transit has loads all over the place, I haven't found them all yet.
Jaws should put some in the sargant box and watch the disco show for entertainment.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
On the Rapido CBE distribution unit the LED is in the fuse holders not the fuses
Andy, good morning just come back from MH and tried everything, even replaced all fuses with blown ones and no "red" light/background....... nothing. So removed cover of fuse box and there are no leds or bulbs behind cover or mounted on panel. It is CBE as photo shows, so must be an old fuse box in a 2011 MH..... I will do some research today on the Benimar MH.
mentaliss
654
306
Lancing
View attachment 48468 To show you the led fuse working I have blown it and this is what you see:
_______________________________________________________
Their not a new ideal they were fitted in my RAPIDO which I sold a year ago...:)
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
I did not post as a "new" idea! only posted to share incase MH owners had not seen them before and also very handy if like my fuse box is in a tight space.
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
On my 09 Rapido fuses were 'lit' from behind, when fuse fuse blew the light went out
Think it was a Scheiber unit
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yup LED's but only on the fuse holders that are actually employed, not the out of use ones.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Andy, heading round to check now as did not try with no fuse in place, but I'm sure it does not do that....
Back soon.
Techno
Jul 28, 2010
15,475
20,756
May 2010
You need the fuse out or a blown one AND the circuit must be on. So if you have switched the lighting on on the overdoor panel you also need to switch a light switch on. removing the lighting fuse should then bring the fuse fail LED on. Same for each circuit.
Don Quixote
Don Quixote
2,966
5,258
VW T6 Campervan
Andy, just back and nop..... no led's light when fuse blown or removed. At least I have my "modded" fuses in place.
