Leaking mixer tap (1 Viewer)
Dai Motorhome
151
19
Burnham on Sea, Somerset
a class
My sink mixer tap is leaking from the base when I turn the nozzle in a particular direction? Anyone had anything similar? Is it a repair or replacement job?
Dai
Feb 16, 2013
19,735
52,033
uttoxeter
ambulance conversion
50 years
Probably just an O ring , if it was mine before replacing it I would have it to bits and have a look , can't lose anything if you are going to replace it any way:thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Just a suggestion.
Sometimes it just appears to be leaking from the base when it is actually running down the underside of the spout. I'd recommend drying the area and trying it again with some kitchen towel wrapped around the stem and see if it still leaks
g8ysn
638
417
ng219ep
coachbuilt
Leaking tap
MORE THAN LIKELY YOU NEED TO REPLACE THE INTENAL UNIT ,IT IS A THREE WAY SINLE UNIT UNDO TAP [ALLEN KEY] UNDO NET LIFT OUT UNIT AND REPLACE,MOST PROBABLY ONE OF THE O RINGS IS LEAKING,DONE MINE A COUPLE OF TIMES ESPACIALY AFTER WINTER:thumb:
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
'Dai' - just love saying that name, reminds me of my schooldays. Everyone was Dai, Dai the milk (milkman), Dai spanners (he was the local mechanic) Dai dog (local hunter type) and then Dai bladders - I won't go into what he was 'famous' for, certainly not on here.
:roflmto:
Just before you remove it (after trying what Techno suggests) try running it whilst on hot and hot water is coming through. A lot of taps get this leak, especially after being parked up, like if the rubber seals go hard.
Had one or two do this but once run on hot which softens the rubbers, helps with seating and I have moved the supplies about underneath the tap, hey presto. Our shower mixer did it recently but same done and we are in business.
Hope it helps.
Trikeman. :winky:
Dec 12, 2010
5,413
21,580
Cumbria
since 2011
When you take the top off the tap, you may see a brass locking ring with two notches in it, try and tighten this down a bit, maybe even a fraction of a turn and it will tighten up on the O rings. Our tap froze up one winter and I thought it had cracked the ceramic valve seat, once I got it apart I realised that the ice had expanded and stretched the body or compressed the O rings and all I had to do was tighten the ring down to take up the slack. You can get replacement cartridge kits from the web no problem.
