Leaking kitchen tap! (2 Viewers)
May 7, 2011
5,962
31,694
East Anglia
Kontiki 669
My Coroflo kitchen mixer tap is leaking from the body
of the tape.As only 3 years old it cant be worn out
surely?
Any body got any ideas?
2,337
10,147
Frost damage.. cracked during the winter .. did you fully drain down .. ?
Jo662
May 7, 2011
5,962
31,694
East Anglia
Kontiki 669
Dont think so Jim as its kept in a garage.
Could it be the micros cartridge letting it
leak through?
Jo662
May 7, 2011
5,962
31,694
East Anglia
Kontiki 669
Yes same make,but cannot find exact tap.
They must do cartridges for them but cant
find on that site as yet.
2,337
10,147
Thank you Jim.
The L180 tap looks like the one,but says without micro
switch.How do I know if mine has a micro swith or not?
if you have a submersible pump.. it will have a micro switch.. also look under the sink.. wires coming down from the tap.
if you have a Surflo pressure pump .. no micro switches
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
If it's like this one..
I had a similar problem but it was only loose. I was able to re-tighten it by hand (gripping the middle section) and it's been fine ever since.
Jo662
May 7, 2011
5,962
31,694
East Anglia
Kontiki 669
Its got the same body as this one,just a different top.
Jo662
May 7, 2011
5,962
31,694
East Anglia
Kontiki 669
Will check if got wires underneath worktop
Muddibootz
166
114
North Shropshire
Elddis Autoquest
since 1994
If you try tightening the middle section, it will be obvious if it's loose as it will easily turn slightly. Mine is just hand tight and has been ok since (over a year)
