Lead acid batteries (2 Viewers)
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
One for Pappajohn
Are some lead acid batteries sealed for life and never requiring distilled water putting in?
Just looked at one of my leisure batteries and there seems no way in to it, the other seems to have the normal plugs in but not as handy to get at until I empty the garage out------Thanks
jonandshell
5,476
8,299
Not got one!
Yes! They are sealed lead acid batteries! Designed for the modern motorist who doesn't top things up or check levels!
The disadvantage is you can't fast charge them like an open (top-uppable) lead acid battery!::bigsmile:
43,332
49,525
yep...sealed for life have a special vent which condenses water/acid vapour (gassing) back into the cells.
im surprised a leisure battery is sealed for life....probably just an engine battery sold as a leisure battery.
In theory.
Give me one I can top up any day.
You get loads of information from looking into a cell. If it's low a lot then your charger could be *******ed.
aba
2,775
1,112
yorkshire
dec 2009
Unless its a gel battery then it's a whole new can of worms.
But then again Alan would have said it was gel not lead acid :Doh::Doh:
43,332
49,525
if it is gel it will be buggered in no time charging on a flooded cell charger
gel and lead/acid have different charge regimes.
Feb 27, 2011
14,741
76,076
I have VRLA batteries (AGM) and they can be fast charged. They have a mechanism inside which combines hydrogen and oxygen back to water :thumb:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Give me an old school lead acid battery any day. Just by taking the tops off you can determine everything that is going on from overcharging to a cell down. There is only one way to check if a battery is any good and that is with a hydrometer. If you cant put a hydrometer in it how can you tell if its goosed ?.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Dunno Ill ask the misses:winky:
