Kruga awning room
Discussion in 'Motorhome Chat' started by peter marshall, Oct 31, 2012.
  1. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    I recently sold my awning has it was to short for the new MH, I am looking at the Kruga room same has the Fiamma and Omnister, but half the price, I have the Omnister windout with the 6mm groove, I have received an email from a supplier that said the Kruga room has a 4mm beading to fit both the Fiamma 4mm and Omnister 6mm, the question is what is the possibility of the beading coming out of the 6mm , I know the feeding slot is narrower than the groove but don't want to buy if it will need a converter strip. Pete :Sad::Sad::Smile::Smile::Smile:
  2. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Well 92 views and 50 odd on the last one on the same subject and not one reply, surely I have not stumped this font of wisdom. Pete :Wink::Wink:
  3. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    no expert but i use a room on my awning, only thing i can say is the slot that you feed the bead into is narrow because the material bit that comes out the slot is the same thickness no matter whether for a 4mm or 6mm bead area behind it.
    I actually use RV twintrack, which give me two channels so i can have the room up but also have a sunshade up as well or i can use it for running lights.
    http://www.rvtwintrak.com/
    the pic on the link gives you a good pic of the slot and area behind it that the bead goes into
