Kazimondo (1 Viewer)
KAZIMONDO
4
MANCHESTER
CREWE BUS CONVERSION
NEWBIE
Hi I am a newbie just bought a Crewe bus conversion, unfortunately it leaks bad:cry: so i thought you guys could help what is the best way to make it water tight, what materials or is there a company near Manchester who specialize in repairs, but not too expensive, the van cost allot, so very little left, Cheers
:Smile:
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Where's it leaking, is it a van if it is leaking isn't usually a problem, what do you meen by a lot of money, is it warrentied, get back to them
Carol
14,051
112,114
North Wales.
Hi welcome to fun, if you don't get the info on this thread try starting another one with " Leaks in van ". or something like that, for the title then the technical folks out there will look in, like chaser says the more info the better. :Smile:
Nov 30, 2009
6,547
148,986
Pickering
PVC the PUG
Hello welcome to the forum. It's forecast a nice dry week, so you may still get to use it, without getting wet:thumb:
Till you fix it:winky:
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
HI AND WELCOME :thumb:you say it's leaking all over can you be more specific IE leaking from roof vent or from a side window etc ? If it's a roof vent remove the internal covers and unscrew it then from the top get something like a paper scraper to gently cut through the sealant and lift it-clean it all down and get some none setting mastic or caravan seal/tape then refit :thumb:While it's off check how wet the ceiling boarding is - chances are you may have carpet on the roof which is easier to dry out -some pics may be more helpful
terry
TheBig1
17,630
43,277
as its a crew bus, it can only be leaking through parts where the roof has been cut, unless its been damaged. non setting mastic tape should be used to bed in any skylights or vents. if something has punctured the roof, a sheet of aluminium bonded down over the hole with sikaflex will work. i used this method to waterproof a crack in a hightop van once and permanently fixed it
a photo of the leaking area would be a great help to be able to offer more specific advice
