Is it ok to leave EHU lead connected?? (1 Viewer)
errpaul
538
83
Wiltshire
11 yrs
We've finally collected our very first MH...can't wait to get out in it this weekend.....:thumb::roflmto::roflmto::thumb::thumb::roflmto:
Anyway...One (more)::bigsmile: thing I was wondering is if there was any reason not to leave the EHU lead connected when the van is parked on the drive not in use?
When the MH is on the drive there is no access to the point at which the lead connects to the van, and so are not able to plug in and unplug as needed.
We would then plug this into our house mains to keep the leisure battery topped up among other things.
N
N Luyetund
You'll get (hopefully :winky:) lots of different views ....
Mine stays connected whilst on the drive.... didn't stop me having to re-charge the veh battery .... hab bty was OK though............
takeaflight
255
Stratford-upon-Avon
Hymer
I thought it charged both :Eeek:
I'me sure someone will come along and tell us :Smile:
American Dream
156
Lincoln
Hiya,
Ours stays connected all the time it's on the drive.I added a point in the garage to attach it to.
I have the leisure battery charger which I switch on every couple of weeks just to ensure the batteries don't discharge and a charger connecter to the vehicle battery which automatically senses battery condition and tops it up when required (the vehicle demobiliser does drain it after a while)
The fridge / freezer is switched on every now and then :RollEyes: throughout the season.I find it's better to run these things rather than wait until you're ready to roll and find for some reason they are not working.The same goes for the engine/clutch/gearbox and running gear hot water/pumps and blown heating.
I do a full functionality check every weekend, just to be sure.
Enjoy the Motorhome guys.::bigsmile:
Steve.
sirhandel
25
Chippenham, Wilts
Best thing is to take the MH out for a run every couple of weeks for about an hour. This tops up the batteries and ensures the mechanicals get some exercise. We live in the sticks so go do a major Tesco shop (about half an hour away) with the MH a. Big advantage is that my wife likes to dawdle around the superstore while I have a snooze in the MH. She calls me when ready to checkout so I can make her a cuppa and then go to help.
haganap
12,761
26,450
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
:Smile:
Depends on what van and charging system that you have. Some do and some don't, mine thankfully does.
Mine also stays wll and truly plugged in when on the drive, not caused a problem with either of my vans and its been done for years that way. I come back and then plug it in.
The best advice given was to use the van. It makes such a difference to keep all the mechanics turning. The worst vans are alway the ones where they are left standing for months on end.
GJH
29,450
38,827
None, now sold
2006 to 2022
Our EHU is usually connected over winter when we might need to use an oil filled radiator overnight to keep the temperature above freezing but at warmer times of year tend to just plug it in to make sure the fridge is cold before a trip.
Our charging system doesn't only charges the leisure battery so I have a Tronic T4X charger (Lidl version of Ctek) which I use if necessary to boost the van battery.
As others have said, it's a good idea to go for a run every week or two to keep the wheels turning.
Graham
brianju
168
35
Hampshire Hogs now in Mid Wales
A class 1991 Hymer B544
10yrs ish - US 5th Wheel/US RV/Eurovan
Excellent :thumb:
Julia
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Hell of a man.
Most men would spend the time shaking, not daring to leave the Thetford.
We, the normal men of FUN, salute you.
errpaul
errpaul
538
83
Wiltshire
11 yrs
Thats brilliant, thanks for your help everyone.
I assumed that the leisure battery would be charged automatically if EHU was connected. How do I know if this is the case with our MH?? It's a 1999 autosleeper pollensa.
dikyenfo
44
lincoln
A class Mc Louis with small trailer
1 year
A relay controlled by the ignition separates the 2 batteries and the fridge there fore consider fitting a solar panel that will keep both batteries charged if you fit a piggy-back split charger.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
If unsure on what gets charged and you can,t find out from the manual, I would give Autosleeper a ring they are normally helpful:thumb:
Dave
43,331
49,460
now i may be a bit fik or i could be missing the point but if its plugged in in the house why do you need access to the point on the van......just switch it off in the house:Doh:::bigsmile:
until i fitted my solar panel i used to plug into the garage...proper 16a eurosocket fitted...for a day every couple of weeks.
kept the batteries charged and no chance of overcharging them.
TonyIsh UK
120
Some thoughts on leaving the EHU connected at home.
1) Protect the mains lead with a RCD, in case the local hedgehog bites through the cable thinking its a very big worm.
2) Halfords (and others) sell maintence chargers which are relatively cheap. Well a lot cheaper than having your M/home internal 12 volt unit having to be replaced because it is left on all the time. I run one for each battery on a time switch using cheap rate electricity just topping up / maintaining the batteries.
3) Some M/home 12 units charge the leisure battery and the vehicle battery, some dont !. Our Rapido charges the vehicle battery after it thinks the leisure battery is charged fully. A cunning plan by Rapido, BUT falls apart if the leisure battery is old and fools the unit into redirecting its charge !
4) A cheapo LCD multimeter ( Maplins about £7.50 last time I looked) is one of the most usefull tools in the toolbox for measuring voltages.
5) Using your cheapo meter, A battery on charge should be between 13 and 14.5 volts (approx), not on charge will be between 12.25 and 13 volts (approx). Below 12 volts the battery needs charging !
6) Some control panels have Voltage readouts. My readings are a constant 0.5 volts below the voltage at the battery terminals.
7) We tend to turn the mains / 12volt unit off at night because it hums. Not noticeable in the day, but enough to annoy at night. Also seems pointless running the unit unless you need 12 volt power or battery top up.
8) French sites can run as low as 4 amp, I would rather that the power goes into an elecy heater (500 watt Dimplex) rather than the mains / 12 volt unit.
Just passing thoughts.:thumb:
Rgds
errpaul
errpaul
538
83
Wiltshire
11 yrs
My question was me being a bit fik....I didn't know if having the EHU plugged in with power only going through it sometimes would cause any problems (no idea what kind but wouldn't wanna find out the hard way).:Sad:
::bigsmile:
