inverter
Discussion in 'The Beginner' started by Spade, Aug 9, 2014.
  1. Spade
    Spade Funster
    Aug 5, 2014
    104
    24
    Hi again.
    Can I ask another question please.
    I have looked online but the info is complicated and device specific
    The van has two leisure batteries with a 2 foot x 1 foot solar panel to help charge them
    There is a 1000 watt inverter also.
    My question is when I am wild camping.,what 220 volt items could I run?
    I know I can't run something over 1000 watts.
    I know that I can run a laptop but for how long?
    So I suppose I am asking how big is it (inverter )
    And what do you run on it.
    A bit longwinded I know
    Thanks for reading
  2. ukbill
    ukbill Funster
    Nov 3, 2011
    4,908
    4,870
    benidorm
    others with better knowledge will be alone hopefully to put u right but i reckon a no no is the fridge have this on the gas at all times a tv is also i large puller of leci but most it will depend on the amps of ya solar i think
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,974
    2,803
    Kendal, Cumbria
    Your solar panel is very small so you can almost disregard any help it offers. You can run anything off the invertor up to its rated continuous output. The wattage of any appliance you plug in will determine how long you can use it. In the case of your laptop its consumption will be marked on the PSU. Anything you connect will draw W/12 amps from your battery so if your laptop consumes 50W then 50/12 = 4.2A is being taken from the battery. A 100AH battery will in theory last 100/4.2 = 24 hours powering only your laptop. In practice it would last about half this time because it is unwise to discharge the battery by more than 50% of its capacity.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    As already pointed out, the panel is just short of useless except for keeping a fully charged battery fully charged.
    It sounds like a 50watt panel which, at best, will theoretically produce 4 amps but in reality will be nearer to 3amps.
    Your 1000w inverter, used to its full potential, will draw 83 amps per hour from your battery so a 100ah battery will last around 20 to 25 minutes.
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,759
    3,258
    Eastbourne East Sussex
    Also your 1000w inverter may be 1000w peak, in which case its continuous output may be only half that. Get a couple of 120w solar panels and you could be independent of ehu.
Similar Threads
  1. RS SPIKE
    25
    995
