inverter (1 Viewer)
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Hi all,do i connect my inverter to the starter battery or the leasure batteries? also what size fuse and cable size do i need for a 1500 pure sinewave.
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Some will say different, but DO NOT connect to starter battery ONLY "Hab" batteries.
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
Simply as a common sense measure, to the Leisure battery,,
It can and will work from cab/starter battery BUT if you over use the inverter and flatten the battery you face the issue of not starting your van... SIMPLES :)
scotjimland
2,324
10,065
A Woosh bang
Use leisure battery
cable size depends on length of cable run.. so keep it as short as possible..
a 1500w inverter takes 125A on full load ,(watts/voltage )
calculate cable size here .. http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
example.. a 1mt run would need 16 sq.mm cable
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
250amp fuse, wire will depend on length. 16/25mm if not sure best to get someone to do it for you. You may be pulling 150amps. wires get hot very quick if not correct.
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
And don't forget the RCD on the 22o VAC output.
1500 is more than enough to kill you
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
thanks everyone got the correct size cable just need the fuse also one more thing i have two banner batteries side by side and linked together . do i put the live from the inverter to one battery and thr negative to the other batt.
Steve
1,613
2,062
Compton Berkshire
C class
both to one battey....you may get a bit of a crack when you first connect so dont jump too high.
scotjimland
2,324
10,065
A Woosh bang
either way.. but pos to one battery and neg to the other is preferable
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
will i get a 250amp fuse from a car shop?
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
thanks everyone will post when its up and running bit of shopping to do
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
While your at it, Using a minimum of 25mm2 Cable connect the positive of the engine battery to terminal number 30 on a 300 amp relay (fused both ends) and connect terminal number 87 to the positive of your leisure batteries (again fused both ends). Connect terminal number 86 to your flag terminal on your alternator. Connect terminal number 85 to the negative pole of a battery or the chassis
Using the same gauge cable uprate the Negative battery lead on the leisure batteries to the vehicle chassis and as Techno said, connect Pos-Pos and Neg to Neg using the same size cable on your two leisure batteries (to equalise the load)
If you do that, you will be able to use your inverter whilst on the move, and tickover should your leisure batteries be a little flat!
Just though you may as well whilst sourcing bits and making up batteries leads etc.
Eddie
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
what size fuse should i use each end also my two batteries are connected together with quite small gauge wire with inline fuses do i leave these in and just connect them pos to pos and neg to neg with the 25mm cable?
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
Connect up with 25mm2 cable and remove the boot laces.
25mm2 cable is rated nominally at 170 amps so you wouldn't want the cable giving way before the fuse so 150 amp Mega fuse would be fine
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
where do i buy a 300amp relay ebay is very expensive
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
so i remove the bootlaces that leaves one going up into the van is that one ok to leave?
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
In reality it doesn't need to be so big Some thing like this would do it Broken Link Removed
That unit means that you don't have to wire to the alternator as it senses the engine is running via the rise in voltage. You can also wire that unit to give you emergency start should the engine battery be flat
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
Yes that would be fine to leave as your not adding anything additional to that circuit.
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
If the basic inverter is 1500 watts it probably has the capacity to cope with a higher wattage at start up. My 1500 watt can take up to 3000 watts which of course raises the requirements. I have a 250 amp meg fuse and 70mm2 cabling joining the batteries together and feeding the inverter. I have just spent a happy couple of hours wiring up 2 inline RCD units as off the shelf plug in ones would not fit the design of the inverter.
http://cpc.farnell.com/pro-elec/rcd-3e/in-line-rcd-unit/dp/PL10051
JanGar
111
37
Fife, Scotland
Hymer
I am a newbie
Thanks for that, the rcd looks ideal.
