Inverter questions (1 Viewer)
Feb 26, 2013
1,653
9,417
Pinar de Campoverde, Spain
Giottiline T60
Since March 2013
If using a 1200W hairdryer is a 1200W inverter sufficient or is it better to have a larger inverter than the power of the appliance you are using?
The price of inverters varies tremendously so has anyone bought one of the cheap eBay modified inverters for £30 and found them ok or are they best avoided for a better quality.
Does anyone have an inverter they are using that they would be happy to recommend? ::bigsmile:
tonka
10,833
21,538
Cannock, Staffs
A class Burstner 800
Since 2000
Its always best to have it larger than needed then it's not working out at full capacity.... Dont think your are going to get anything that big for £30. AND watch how they list the power, sometimes they list the very maximum and the inverter can only stand that for a short time...
NOTE.. 1200 watts is 100 amps !! So even using for 5 mins will take about 8.5amps out your battery.. Cut down on the heat and use a lower setting, that will reduce the wattage required...
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Please can you explain how you work this out. I would like to know so I can work out an idea of how much I can use tv, laptop etc while wild camping. I thought I remembered it from college but now I'm confused.:Blush:
tonka
10,833
21,538
Cannock, Staffs
Since 2000
It's a think called Ohm's law... Do a google search but dont cry as you read it, really it is easy..
1200 watts of power (the amount used by the dryer) divide by the voltage.. in this case leisure battery at 12v = 100amps
Now this figure is based on an hours use. So run that dryer for an hour and you will consume 100amps.. AND before anyone gets to technical and says "but the Inverter uses power" I am trying to keep things simple..:winky:
so 100amps in an hour divide by 12 (5 min sections) = 8.33 amps in 5 mins...
Now the Inverter will consume power and have some loss, say 10% so add another .83 amps... Total use around 9.16 amps..
Does that make sense...
Another example.. TV... LED low power, 20watts..
20 divide by 12v = 1.66 amps per hour...
It's a basic formula and almost every electrical device will state its power in watts.. Big items like heaters use kw (kilowatts) 1,000 watts = 1 kw
Here ends today lesson..
Tomorrow.. Opening cider tins and their re-cycle uses lol
Bailey58
8,818
29,603
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Plenty of threads on inverters if you care to search, I installed a 2000w to run bits and pieces when off ehu. Fine for the 900 watt kettle but failed miserably to run a 1450w coffee machine. It's been said they only run at 70% of there stated wattage (if that) if I remember correctly so you're asking a bit much of it for the dryer. :Smile:
Edit: Just re-read your post, mine's a Ring from Halfords, paid about £210 for it when on offer in May.
JJ
Mágica
May 1, 2008
19,259
48,055
Burstner Privilege T
over 50 years
I do believe that watts and amps calculations must be made with the voltage taken into consideration... I don't think 3 amps at 12 volts is the same as 3 amps at 220 volts!
JJ :Cool:
jonandshell
5,476
8,299
Not got one!
Our 2100 W Ring inverter achieves its rated output easily.
Was it your inverter of battery which wasn't up to the job?:Eeek:
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Sack him !!!!!!!!!!!
Should be able to do it in his head or on a piece of torn off cardboard and a stubby pencil..
:ROFLMAO::ROFLMAO:
JJ.. Yes 3 amps at 240v and 12v are not the same..
One will give you a "tingle" the other :cry:
Let me give you a clue our fitters nickname
BLACKDOG
He owns 3 tools
14 pound hammer
Big shifter
Just in case 28 pound hammer
Bailey58
8,818
29,603
Norfolk and Toftir.
Sold
Neither, the coffee machine's a complicated bit of kit.
T'was explained on earlier threads. My internet, phone line is about to be cut off, we're on a ship or two to the UK today.
electricscott
203
66
Buckden Marina
3 year
JJ :Cool:
amps are the same, what is different is the amount of power they can generate and this down to the voltage since watts = volts x amps so:
3 x 12 = 36 watts
3 x 240 = 720 watts
garlicmonster
15
Derby
newbie
.... of course a hairdryer is also an inductive load, so you really need to consider the power factor
On a.c.
P=VI cos phi
But that's just me being a pendant
oldun
747
162
St Neots
VW Campervan
Since 2001
The above is pure gobbledegook...
For example "So run that dryer for an hour and you will consume 100amps" ---- this should be 100 amps instantaneous power and will deplete the battery by 100 amphours.
Amps is a bit like speed, amp hours is a bit like distance.
All in all a very misleading and confusing post.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
as a quick guide I use, 1amp @ 230v = 20amp & 12v
schojac
339
234
Cambridgeshire
new in 2009
I have a 1500 watt modified sine wave inverter and it works fine with a 1200 watt hair dryer. It's not too happy on full load and on reflection would have bought a slightly higher - 2000 watt.
The inverter cost me £30.00 but remember it's a modified sine wave inverter. People have stated that if you intend to run TV's, computers etc then yopu may need a pure sine wave inverter which costs quite a bit more.
When connectining to the leisure batteries you will need some heavy duty(16mm2) cable to carry the load efficiently. 120 amp inline fuse and good connectors.
The hardest part is bending the heavy duty cable so suggest that if you intend to install that you keep cable runs short and as straight as possible.
Coolbeanz
Feb 26, 2013
1,653
9,417
Giottiline T60
Since March 2013
So can anyone tell me if I have worked this out correctly:
I can buy a 1500w modified sine wave inverter and it will cope fine with my hairdryer.
I need to wire the inverter as close to the leisure batteries as possible.
As my TV runs on 12v and my IPAD and IPhone both charge using a 12v adaptor there is no point getting a pure sine wave inverter for them.
If I want to charge my electric toothbrush I could buy a 150w PSW inverter.
Lastly am I right in thinking that running the TV off 12v would drain the same power from the leisure batteries as connecting an inverter and plugging the TV in to that? :whatthe:
Steve
1,613
2,062
Compton Berkshire
Put like that then yes it will work.
On you last question, power is power be it at 12v or 230v but you use power to convert 12v to 230 so if you have 12v equipment then I would you it.
Steve
schojac
339
234
Cambridgeshire
new in 2009
Hi,
basically Yes to most of your answers.
If you have a 12V TV then run it straight from your 12V supply; running through the inverter will not be as efficient due to power loss.
As daft as it may sound the inverter was bought purely for the hairdryer
"I can't do without the hairdryer" says she who must be obeyed. Carole does not use the dryer on full power and she gets 40 mins drying time easy (2 x 100amp/hr batteries)
Expensive option but I think long term (aires, CL's etc) it will pay for itself in no time.
jonandshell
5,476
8,299
Not got one!
Hi,
Women and hairdryers is the number one reason for inverter purchase in the UK I reckon!::bigsmile:
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Or generators :winky:
I bought a generator purely so that SWMBO could dry her hair.
The only other time it has really been needed in anger was to charge my brother-in-laws battery on his caravan, 'cos he was to tight to buy a new one. ::bigsmile:
11,842
14,071
Having measured such things for my own dubious purposes. A 1200w travel hair dryer actually only uses 250w or less on low power.
It will work on a £30 500w inverter cos I've done it. Just don't put it on full power !
Best to buy a bigger inverter though. We use a hairdryer (1200w) and a toaster (650w) on a daily basis while away and our 400w solar panels will have the batteries fully charged by lunchtime if reasonably bright. Abroad when the sun shines we use an electric kettle as well.:Smile:
