Inverter question (1 Viewer)
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
At what stage of the battery charge condition will an inverter stop operating?
I am have trouble the minute my batteries drops lower than 12.6 volts and feel this cant be right.
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Cool: How far away from the batteries is the Inverter? Is the Inverter directly wired to the Batteries or is it connected via the cigarette lighter connection? :winky:
The Inverter should work down to 10.9 volts (unlikely depending on current draw) more or less.
43,334
49,533
what you checking your battery voltage with John.
i think they drop out at around 11.5 volts and mine has an audible warning when it senses low battery then a few mins later it turns off.
Road Runner
Road Runner
1,143
1,445
Europe
yes
If i try running it off the RVs leisure batteries it doesn't last very long through the vehicle power sockets.
I have a spares 110 amp battery and sit the inverter on top and last lot longer but inside the vehicle.
Say i wired the inverter outside near the leisure batteries would i need to go out at night and turn it off?
My current inverter is 300 watts but looking at the 600 watt maplins one for £39.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
whilst a fully charged battery is 13.8V or there abouts a reading of 12.6 is considered half charged thus a regulator will prevent further use to prevent damage to the battery. the levels are sometimes adjustable. Inverters use a lot of battery power12V does not magically become 240 or 110V, it comes at a cost and that cost is in amps. Answer is to use less mains voltage appliences when not on hook up.
Road Runner
Road Runner
1,143
1,445
Europe
yes
At present only use 240 volt on ordinary 20 inch TV and Sky box.
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Cool: I currently (pun intended) have an 800 watt fitted directyly through the floor to the batteries. I also have a 1500/3000 watt 110 volt directly wired in the AGM (6x100ah) basement storage area. I intend (and you CAN too), extend the ON/OFF switch into the RV. Similar to the remote for the genny. :winky:
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:RollEyes: I must make the point. In our Kontiki. The 300 watt Inverter plugged into the cigarette lighter socket beeps like crazy with JUST the laptop connected. :Eeek:
TOO MUCH voltage drop.
Road Runner
Road Runner
1,143
1,445
Europe
yes
I was amazed to realise how much wattage a laptop takes when being used direct:Doh:
rather than just charging, it's a real eye opener:whatthe:
Thepips
Trade Member
Sep 26, 2007
493
Basingstoke
RV
Hi John,
A modern laptop won't need more than 70 watts, 6 amps but you'd need to be watching a DVD, with USB powered speakers and charging a flat laptop battery.
Regards
Doug
gavel
20
East Anglia
Low profile
4 years
inverter
We have a 300 watt peak inverter and want to charge our disabled scooter whilst on the move. The scooter is in a trailer. Can this be done please ?
Douglas
2,835
400
South Wales,
I see a lot of figures bandied about in regards to battery voltage, the figures above I think are a typo as wildman lists his interests as Ham Radio
First let me say that TRUE and again I say THE TRUE battery voltage can only be measured when the battery is at rest.
To give you an example: I have 3 batteries that I keep as spares at home, they are in very good condition and even after they have been off charge for over 2 weeks they are still reading a voltage that is called surface charge IE greater than that of a fully charged battery, of course if I put a small load on them the surface charge will quickly dissipate and then read the true voltage of about 12.8 for a fully charged battery
Please get it into your heads that you cannot measure battery voltage when it is being charged or discharged, you have to let it rest for a while and after charging apply a small discharge then let it rest first.
Doug
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Doug
13.8V is the level at which my regulator stops charging a battery, it will of course settle after a while,l why do people have to be so pedantic about such things. I try to state general facts that can be understood by the majority of people without going into degree level explainations. The majority of readers just get confused otherwise.
43,334
49,533
i would doubt it on a 300w peak inverter:Sad: chances are its only 150/200w constant output which is less than 1 amp.
the scooter charger will take quite a bit more than that i would think!
Douglas
2,835
400
South Wales,
Roger, of course you are correct. Incorrect information is confusing. Some one who did not know better would read from your post that a fully charged battery would have a voltage of 13.8 which you and I know is not correct.
As to being pedantic I disagree, in this instant the information is either correct or not correct and to the people who are looking for information it is VERY IMPORTANT.
Sorry if I have upset you, but that is better than some poor guy stuck somewhere with a battery problem not understanding why his battery is not reading 13.8 when it only reads 12.something.
Doug
Road Runner
Road Runner
1,143
1,445
Europe
yes
Caravans have a lead that charge the caravan battery on the move, could you do something along these lines?
Losos
549
4
Suffolk & Czechland
Looking to buyi
N/a
Roger, just as a matter of interest what equipment in your MH is 'mains only'
I ask because I will shortly have to do a 'power budget' for all the equipment to be installed in my MH and I'm thinking that maybe I can get away with only the microwave being mains operated
43,334
49,533
i have 6 mains powered appliances,
aircon....occasional use, 230v only item
microwave.....occasional use, 230v only item
heater......mainly on gas, much warmer. 230v and gas
water heater......mainly on gas, hotter water, 230v and gas
fridge.....always, on hookup, 3 way unit
charger.....always, on hookup. 230v only item
so only 2 items always on mains.
Tony Lee
274
More on the OP's problem.
Most likely to be caused by excessive voltage drop in the wiring supplying the inverter. Even a small 300W inverter can drag 30 amps and unless the wiring is substantial AND as short as possible, you could easily lose a volt or more.
With the inverter loaded up, measure the battery voltage and also measure it at the inverter terminals. Less than half a volt difference is acceptable but a quarter of a volt would be better.
If you choose to install proper wiring, make sure you include a fuse as close to the inverter as possible. A 40 amp fuse in conjunction with appropriately-sized wiring would be good.
2,346
10,186
Hi Tony
The fuse is to protected the wiring, so it should be close to the battery .. why do you suggest placing it close to the inverter ?
Jim
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
very simple to answer that one, currently none. We always wildcamp so no mains hookup, hence no mains appliances carried. We do have an LCD TV that consumes 4amp though an inverter but usually use the 1amp black and white unit. and thats the lot. Charger is engine or solar, don't have a mains charger built in. Whilst I do carry a generator we have never actually used it to charge anything. It is just for emergencies.:thumb::thumb: Motorhoming is a different way of life we conserve power yet still have TV on a good 6 hours a day. So no problem. By the way now have a number of woodwork machines for sale if you want to take some back with you. also a camping space here for you.
teensvan
63
Fulltime in Motorhome
Hi.
One thing that most people miss is that when a TV Or laptop is powered up it requires an inrush current to start up. A small inverter running of a single 3/4 charged battery will not be able to give the start up current. All 12 volt leads should be as short as possible. No more than 3 feet or you start to get a volt drop. Cable size should be at least 16mm.
steve & ann. ---------- teensvan
