Inverter on HymerB584 (1 Viewer)
B
barnstormer
I have purchased a 500 watt inverter to use on the rare occaisions I stay in a site without hookup.My leisure battery is located underneath the drivers seat and not very accessible.
I am wondering where in the vehicle I can connect to?Has anyone experienced the same problem?Any ideas would be welcolm.
Regards
Barnstormer
highwayman
968
1,029
Herne Bay
Low profile Rapido
Since 2005 ish
Hi barnstormer
We made-up a 12v extension lead using parts from maplins and keep this connected to the leisure battery, then just lay-it out and use-it when needed. :thumb:
To be honest i couldn't think of another way of doing-it at the time and havn't bothered since as it works! :thumb: :thumb:
regards...nige
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
An inverter will draw huge amounts of current, slide the seat off its mounts to reveal the battery. then using heavy duty cables connect using very short leads a bracket mounted 20amp Cigar socket into which the inverter will plug. Plug it in only when you need it which should be very infrequently. Inverts use huge amounts of current and will flatten a small battery very quickly. You are better off changing to 12v appliences, Battery power is a finite resource.
