Intermittent lack of accelleration. (1 Viewer)
spotsy
28
Durham
since 2004
Hi all, can anyone explain why my 1997 Fiat 2.5 TD sometimes loses accelleration even going downhill at full throttle speed cannot get above 42 mph ?This situation has been happening lately, the engine somehow rectifies itself and accelerator acts normally.
Advice much appreciated.
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
Sounds like fuel starvation to me. Change the fuel filter and see if that works. It could be debris floating around in the fuel tank.
spotsy
spotsy
28
Durham
since 2004
fuel filter
Thanks for reply but did a full service recently including filters.
43,367
49,720
sticky turbo wastegate actuator.
need to locate the linkage and plunger between turbo and diaphram body, spray with WD40 and work by hand until smooth operation.
spotsy
spotsy
28
Durham
since 2004
Wastegate Actuator
Thanks PapaJohn, will check that out tomorrow.
Snowbird
11,818
22,347
Liverpool.
Fifth wheel.
Since 11-05-2000
If you did a full service recently, did the problem start after the service or before ?.
43,367
49,720
wastegate temporarily stuck open/partly open will reduce turbo pressure and performance.
friend of mine had the same issue with his toyota people carrier, his was stuck open all the time.....freed it off and power back to normal.
Nov 18, 2011
11,862
43,230
Planet Earth
A van
Over 25 year's
fuel system drawing air casing fuel starvation if you have only had problem from servicing
spotsy
spotsy
28
Durham
since 2004
wastegate
Hi again,
Snowbird; this happened after service.
Pappajohn: Been under bonnet and excuse my ignorance but I cant locate the actuator ? any guidance would be appreciated. To re cap the engine is a 1997 ducato 14- 2.5 td. Been searching for a workshop manual and not found one yet:Sad:
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
the turbo unit and its linkages are fitted at the rear of the engine block on that engine if i remember correctly. the best way to access it is from underneath ! very awkward unless you have lifting equipment or a pit ! regards garry
