Interior mods (1 Viewer)
Oct 29, 2021
990
6,378
Chesterfield, UK
autocruise Rhythm
Most of my life in one form or another
i have a couple of units im going to modify to install some drawer units.
I will need to cut the base unit down neer the floor , down both sides and along the bottom to make it deeper( maximise the available size)
What do you reckon the best saw would be to use, space is limited and i cant take the units out.
Thanks for any advice.
Lenny HB
53,484
150,245
On the coast in West Sussex
Hymer B678 DL
If you don't know what saw you need I would leave well alone.
You could fit draws inside the cupboard but what happens if you need to get at the gas taps in an emergency, or are you planning on repositioning them.
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
Why don’t you just find some plastic boxes that fit. Almost as convenient as a draw.
dazandandrea
Oct 29, 2021
990
6,378
Chesterfield, UK
autocruise Rhythm
Ive looked into that and tried them , far too much wasted space and poor access added to the deep drop on the front.
Minxy
32,667
66,625
E Yorks
Carthago Compactline
Firstly I would NOT cut the exiting units as your cutting the base section will seriously reduce the strength of it, secondly you need to be able to access the isolation taps and be able to do so quickly so blocking them with drawers is a no-no in my book.
What you could do instead is build a framework out from where the taps are and mount some drawers within the unit itself, eg the wire type that you get from Ikea, B&Q etc which come in a few sizes, or adapt standard drawers from a kitchen unit (put drop holes in the bottom of them). Depending on what type of drawers you use you could attached the drop down flap to them and use that to pull the bottom one out. The easier solution though would be to shelve it out and use removable baskets/boxes of some sort, the advantage of that is you can pull them out completely so you can have a good rummage rather than bending down to try to see what's in there and also take the boxes in to the house to pack stuff - this is a method I've used for many a year and works very well - if you have one of those plastic storage units you might find the drawers out of that will fit on a shelf.
Minxy
32,667
66,625
E Yorks
You still need to leave a good gap for the gas drop so you can't safely put drawers right down to the bottom.
Jan 8, 2013
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I think any cutting of the existing cabinetry will always look like a bodge and reduce the value of your van.
As Minxy says plastic drawer would be a far better solution
Loads on eBay
Apr 11, 2015
5,419
55,263
hull
Laika Ecovip 300
Was really interested in this thread as i need to cut a door in the front of the seat storage in my doblo to get the thetford in and out. Would need to totally dismantle the unit, electrics and fridge to be able to put it on a bench and cut wondering what type of saw to use too Minxy
Minxy
32,667
66,625
E Yorks
I'd use a jigsaw with a fine blade (drill holes to push the blade through) then before cutting I'd score the front panel to make small groves where you want the blade to go as it can help to keep it running straight. You need to ensure that the blade won't catch anything behind ... it won't be easy to do but if you have a practice on something else first so you are confident with the jigsaw you should be fine. An alternative might be to see if you can just remove the front panel itself.
You'll ideally need something to edge the opening with as it's difficult to get a good cut when you're trying to do stuff in situ but you can get plenty of flexible rubber type trim for that and of course you'll need to make a door for it too.
dazandandrea
Oct 29, 2021
990
6,378
Chesterfield, UK
autocruise Rhythm
What im planning in fitting will not be right down on floor level but raised up a few inches to allow a space under for ventilation.
Thanks for the input.
PP Bear
7,814
28,813
Kent, UK
Auto Trail Dakota SE
Good luck with the mod, I’m excited for you and reckon it’ll be handy to have the extra drawers.
Be careful when cutting it, from your picture it looks to step up with the other panel, or is it double thickness.
Be sure to post pictures when it’s done.
Dont forget, Who Dares Wins 😀
Minxy
32,667
66,625
E Yorks
Sue have you thought of making a 'box' for the toilet near the door which would double up as a place to rest your feet or a seat? I'm not familiar with your layout so don't know if this is possible.
PP Bear
7,814
28,813
Kent, UK
You couldn’t by any chance post a picture stepped back, so we can see the entire area and panel.
Minxy
32,667
66,625
E Yorks
Be careful when cutting it, from your picture it looks to step up with the other panel, or is double thickness.
That's just got me thinking ... I'm wondering if the panels are hollow?
Minxy
32,667
66,625
E Yorks
These are the drawer carcases you can buy which you can cut to size:
dazandandrea
Oct 29, 2021
990
6,378
Chesterfield, UK
autocruise Rhythm
Ill be making the drawer to fit . Re the toilet box i made one when had the vw T25 ill try and find a pic
dazandandrea
Oct 29, 2021
990
6,378
Chesterfield, UK
autocruise Rhythm
I made the box on the right hand side ti fit a Thetford cassette toilet, ciuld use it as a seat as well and was removable to increase load space .
Apr 11, 2015
5,419
55,263
hull
Laika Ecovip 300
Minxy and others going to start a new thread don't want hijack dazandandrea
Jun 26, 2018
1,011
5,417
North West
Florium Wincester
Europe & USA since April '21
In answer to your original question, the saws you mention are great for cutting. I'd practice a few times on a spare piece of wood because they give a bit of a kick and getting a nice straight continuous cut takes care. I wouldn't use a jigsaw as they don't cut all the way due to the blade being recessed back from the body.
May be beneficial to support each side of your cabinetry with a right angle bracket attaching sides to floor. Use a good quality blade when cutting.
Good luck.
Apr 11, 2015
5,419
55,263
hull
Laika Ecovip 300
Looks lovely unfortunately II don't have the floorspace to spare in the doblo, it's mostly a day van but i do go away for a few days at a time in it. Health problems mean i need an easily accessible loo.
