Induction hobs - a way to use non-metallic pans! (2 Viewers)
32,662
66,587
We're in the market for a new cooker and can't decide whether to change from gas to dual-fuel (gas hob and electric grill/ovens) or go full electric (halogen or induction) as we've always had gas, so I've recently bought a single induction hob with the intention of trying it out to see if we like it to help us decide and avoid making a possibly expensive mistake.
Anyway, whilst looking up info about induction I came across a 'plate' that you can use on an induction hob to allow you to use normal (ie non-metallic) pans on it, such as aluminium ones. Apparently they come in different sizes:
I thought I'd mention it in case anyone else is interested.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Thanks for that, just ordered one for the van so I can use the pressure cooker on the induction hob.
dippingatoe
Jul 23, 2013
630
1,232
Thor Damon Daybreak 27P
jan 2014
What induction cooker/hotplate are you intending to use and will it work on any campsite electric hookup ?
Many thanks for any pointers
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Had mine from Maplins. It weighs no more than a laptop and is about the same size. Its worked on every campsite I have ever been on. Link Removed
JockandRita
11,462
150,184
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Dave,
I've been put off an induction hob, mainly for two reason. 1. The non magnetic pans issue, which Mel above has shown us all, can be resolved, (nice one Mel :thumb:) and 2. I don't know about your RMB, but our Hymer trips out at 10amps, :Sad: the amperage required when using the 2000watt induction hob on full. :Sad:
Cheers,
Jock.
jonandshell
5,476
8,299
Not got one!
Confused here!:Eeek:
When did aluminium stop being classed as a metal?
I get it! Induction hobs need ferrous pans to work.:thumb:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Dave,
Cheers,
Jock.
I was told by some when I bought the induction hob, it would not work on campsite hookup. When I bought mine it was on offer at Maplins at £29 so I thought I would give it a go. The setting is variable, but we have never had a problem even on the high setting. Things heat up very quickly in it and you do not require it on the high setting for long. We use it all the time, but it was always a problem using the pressure cooker, which we use a lot.
mobic
15
8
Linlithgow, West Lothian
5 years
Induction Hobs
We have a one ring induction hob and its fantastic. We bought one of these 'converter' plates from Coopers of Stortford by mail order and whilst it doesn't look shiny and high tech it really does work. We only use gas to cook when we don't have a hook up, but as my wife is disabled we tend to use sites with hook ups most of the time and we've had the same gas cylinder fir more than a year now. :thumb:
Jan 31, 2009
494
476
Shropshire
10 years +
Dave,
Cheers,
Jock.
All the vans I've had have had 2 trips - one circuit at 10 amps which supplies the sockets, heating, water heating etc and one at 6 amps which supplies lights etc. 10 amps is 2,300 watts so there shouldn't be a problem unless you are running something else at the same time on the same circuit.
JockandRita
11,462
150,184
Lincs/Cambs border
N+B Flair 8000i
It's a German spec Hymer, which comes with one RCD, tripping out at 10 amps. The upside, is that we never trip the site bollard, only our RCD.
We use a 900 watt kettle, and a 900/1800 fan heater, when being charged for leccy. Nothing left of the 10 amps. :winky:
Cheers,
Jock.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
My advice would be get one when they come on offer at Aldi or Maplins Jock. They do work on campsite electrics, even if you have to switch the heater off for a few minutes. We even use ours at home its so easy and quick and takes no room up at all.
32,662
66,587
Apologies, should have made it clear that the type of pan needed has to be the type of metal that a magnet will stick to for it to work ... not that you need to have a magnet in the pan of course!
::bigsmile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Well it arrived last week and I must say its very good quality and in true motorhomers fashion it now does two jobs. Makes a greet base for the Tomtom sucker to stick too on the dash. No more unsightly sucker marks on the windscreen :thumb:
Heyupluv
3,862
1,593
France,
touring many years..42+
Mel "B".....Don't waste your money on the "plate" they are next to useless....in fact there is one here you can have.....we have had for 4 years + now a induction 4 ring hob.....when we first purchased the induction and because we had many pans in various sizes shapes covering cooking various jobs.. lot of the pans very new of the stainless steel variety ..thinking steel = induction = perfect....not so...so we purchased the plate to act as a go between ....well the heat :Doh: crap it took toooo long for anything to cook..wasted heat between the induction hob and plate...and between the plate and pan..
A good job we only purchased one of the " plates" you have mentioned.
We have ended up buying all new pans that are for induction cooking rings and they are fine...and stored our other pans in case we moved to different property where the cooking is either gas or standard electric rings.... :thumb:
try cooking with the iduction hob with the correct pans you will find a vast difference in cooking.....the plate is realy just a make do job if you don't want to change you cooking pans
Heyupluv
3,862
1,593
France,
Anyone passing by (we live in Northern France) is welcome to our plate for FREE, it is made by Whirlpool and at the time we bought it I think it cost us about £35.
Heyupluv
3,862
1,593
France,
So what you have gone and done is purchased a modern induction hob ...which are very very good..easy to clean...the induction plate does not get hot...and gone back to the old steel cast solid plate ?????? inefficient solid plate...:Doh: why.. plus carrying more items ????...I can see only one reason why Dave (SB) has purchased one his alum pressure cooker...
DON'T forget this one I have is FREE to any member passing...as mentioned above
3,171
9,387
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Caution.
Hi.
Bought an induction hob,after seeing a chap using one on site,great bit of kit.
Breaking the rule of a lifetime,i read the instructions through..." Not advisable to be used if a pacemaker is fitted"
So now that's me doing the cooking,the misses has to be about 5/6 ft away,just a warning in good faith,they are a great bit of kit.
Tea Bag
