Indicator nuisance (1 Viewer)
Swisstony
118
12
Wiltshire
Since August 2010
When I am approaching a roundabout and I indicate 'Right' to go to (Say) the third exit, as soon as I turn the wheel slightly left, the indicator 'Clicks off'. I know they are designed to do this, but it seems too sensitive.
My MH has a Fiat Ducato cab. Can they be adjusted? Is this a common problem? Or is it just mine?
BTW, when it 'Clicks off' (With the steering slightly left), it will not allow me to indicate 'Right'. So I have to wait until I am "Into" the roundabout, before I can tell the impatient Boy-Racer behind me, that I am continuing around the roundabout.
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Is the steering wheel on straight?? It sounds like the collar that turns them off is off centre
43,330
49,446
you should be able to get a quarter to half turn before the cancel mechanism engages.
does the stalk feel secure...no movement or wobble ?
is the wheel straight...spokes exactly/near as damn it horizontal in a straight line ?
any work on front suspension....tracking or wheel bearing replaced ?
Swisstony
Swisstony
118
12
Wiltshire
Since August 2010
I am pretty sure it is. And also pretty sure that this problem works 'Both Ways' so to speak.
Swisstony
Swisstony
118
12
Wiltshire
Since August 2010
I will check some of those out. I have only had the MH for 2 months, so I will have to check with the suppliers ref the last suggestion.
