In hot water??
Discussion in 'Top Tips & Tricks' started by Boo, Mar 17, 2009.
  1. Boo
    Boo Read Only Funster
    Jan 26, 2009
    636
    4
    Cornwall
    Food for thought eh??
    Microwaving Water!
    A 26-year old man decided to have a cup of coffee. He took a cup of water and put it in the microwave to heat it up (something that he had done numerous times before). I am not sure how long he set the timer for, but he wanted to bring the water to a boil. When the timer shut the oven off, he removed the cup from the oven. As he looked into the cup, he noted that the! water was not boiling, but suddenly the water in the cup 'blew up' into his face. The cup remained intact until he threw it out of his hand, but all the water had flown out into his face due to the build up of energy. His whole face is blistered and he has 1st and 2nd degree burns to his face which may leave scarring.
    He also may have lost partial sight in his left eye. While at the hospital, the doctor who was attending to him stated that this is a fairly common occurrence and water (alone) should never be heated in a microwave oven. If water is heated in this manner, something should be placed in the cup to diffuse the energy such as a wooden stir stick, tea bag, etc.., (nothing metal).
    General Electric's Response:
    Thanks for contacting us, I will be happy to assist you. The e-mail that you received is correct. Microwaved water and other liquids do not always bubble when they reach the boiling point. They can actually get superheated and not bubble at all. The superheated liquid will bubble up out of the cup when it is moved or when something like a spoon or tea bag is put into it.
    To prevent this from happening and causing injury, do not heat any liquid for more than two minutes per cup. After heating, let the cup stand in the microwave for thirty seconds! before moving it or adding anything into it.
    Here is what our local science teacher had to say on the matter: 'Thanks for the microwave warning. I have seen this happen before. It is caused by a phenomenon known as super heating. It can occur anytime water is heated and will particularly occur if the vessel that the water is heated in is new, or when heating a small amount of water (less than half a cup).
    What happens is that the water heats faster than the vapor bubbles can form. If the cup is very new then it is unlikely to have small surface scratches inside it that provide a place for the bubbles to form. As the bubbles cannot form and release some of the heat has built up, the liquid does not boil, and the liquid continues to heat up well past its boiling point.
    What then usually happens is that the liquid is bumped or jarred, which is just enough of a shock to cause the bubbles to rapidly form and expel the hot liquid. The rapid formation of bubbles is also why a carbonated beverage spews when opened after having been shaken.'
    If you pass this on
    you could very well save someone from a lot of pain and suffering.
    Or water for thought??
    Boo
  2. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    I thought it was well known that you should let the contents of the microwave rest for a short time to allow the cooking to complete.
    I must however admit that I was not aware of the problem of water boiling over after heating.
    We regularly use the microwave to prepare our bedtime drinks of chocolate - I will take more care in future
  3. scotjimland
    Jul 25, 2007
    28,936
    25,587
