Best and cheapest way. You just have to remove them with the device your using if you want the continental plug 'flap' to close shut.Don't bother,buy adapters
A thanks of my post/link wouldn't go amiss,just saying like.Thanks for your replies
It is an old 2002 Hymer Starline 640.
Easiest solutions are usually too obvious. I have just order 4 adapters!!!
I by them in Poundland pack of 2 for.......£1Thanks for your replies
Sorry but that would look terrible next to a Berker socket.Idea?:
Can you not add a second socket next to original, ie a pattress box and 13 amp socket, all you have to do is wire into back of 2 pin
Broken Link Removed
Although aesthetically different they have the same screw mount centres as Berker I believe.Quite a simple job. Assuming your Hymer is from the early-mid 2000's (possibly more recent too) they used CBE fittings which are modular. You can get replacement centre modules for UK 230 volt ac. Here is one source but several other suppliers sell them too.
If you don't want people to comment perhaps you shouldn't have posted on an open forum.Actually Lenny, I was talking to the OP.
Perhaps you should read Rule one of the forum and try not being so rude.Like I said lenny, I was talking to the OP (trying to find a f**K you smiley but unsuccessful)
A word of Warning. Printed on the front when you enlarge and read them. Is the wording "Not for use in the UK". And the MAXIMUM Load is 7.5Amps. Any Appliance of more that 1800 watts will overload them.
A 2KW fan heater pulls 8.3amps without the motor current. Better to bite on the bullet and have the sockets changed (My View).
The rest of Europe doesn't seem to bother with fuses.Never noticed before......do euro 2 pin plugs have fuses ?
If not, what if you change the appliance plugs for euro 2 pin but only require a 5 amp fuse ?
They use radial circuits each socket has MCB or fuse in the distribution board.The rest of Europe doesn't seem to bother with fuses.
BodgeIdea?:
Broken Link Removed
