Immobiliser Problem (1 Viewer)
starspirit69
4
aylesbury
coachbuilt
My Puegeot Boxer based Autocruise Starspirit has decided to keep the immobiliserer activated despite unlocking the vehicle with the central locking. The indicator on the dash (vehicle with padlock) wont go out so the vehicle wont start. It is under warranty but apparently this does not cover immobilisers allthough it covers central locking. It appears that it has to go to a main dealer OUCH, or does it!.
eddie
8,172
41,376
Taunton Somerset
RV
since 1989
It may not cover after market immobilisers, but how can it exclude factory fitted devices?
What chassis is it?
Eddie
TheBig1
17,655
43,500
it depends on what age the vehicle is, as the older vans had problems with the immobilisers. there is a work around that bypasses the immobiliser but you will then need to have a thatcham approved one retrofitted
for the newer version of the van, it could be the receiver or the ecu thats faulty which should be covered by any warranty. potentially very expensive.
i presume that all the possible resetting procedures have already been tried, like disconnecting the battery for 30 minutes to clear the memory in the ecu and reading any fault codes?
just seen Eddie posted as i was writing. he is the man that knows more than anyone else about these issues
starspirit69
starspirit69
4
aylesbury
coachbuilt
Hi Eddie,
Not 100% certain what u mean by chassis but it is a 2005 Boxer 290 LX MWB HDI 1997cc I feel that as the immobiliser is activated by the central locking and that is covered by the warranty then it should be included but that is my opinion. Thanks for your input.
eddie
8,172
41,376
Taunton Somerset
RV
since 1989
Hi The immobiliser is 100% independent of the central locking. Inside your door/ignition key is a small "chip" and there is a transponder ring around your ignition barrel that communicates with your key when the ignition is on.
I really can't see how a factory fitted immobiliser is not covered under your warranty.
Good luck
